LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,711
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Your getting it done, a disc will not get a level surface most of the time,
you could get a small log or pole and chain it off the disc to pull behind you.
Or a spring tooth or spike tooth harrow to pull behind you at the same time.
I don't recall if you mentioned your plans for this after your are thru discing,
but if you are going to be using a tractor after it is planting and growing,
I'd be sure that my last tillage pass was in the same direction that I would be planting or harvesting or mowing,
otherwise you will find the ground has been compacted by the tire tracks and it will be a bouncy ride crossing those lines.
