URGENT tow drop hook
/ URGENT tow drop hook #1
neilftaylor
newcastle uk
ford 4630
i have a tractor ford4630.
i cant work out how to drop the hook at the rear,cant find a control?
can you help
Neil
/ URGENT tow drop hook #2
Do you mean the 3 pt hitch? Photos would help.
/ URGENT tow drop hook #3
Can you describe what a "tow drop hook" is?
Buy a manual for it, it will show you every thing you need to know.
/ URGENT tow drop hook #5
"...separated by a common language."
Diagram showing part names:
Bruce
/ URGENT tow drop hook #6
OK Neil.....we need pictures. Nobody knows what you are talking about.
Kevin
/ URGENT tow drop hook #7
I'm guessing its a European style implement hitch, their not used in North America so most of us won't be much help.
/ URGENT tow drop hook #8
They tow trailers on the roads over there.
Tractor_and_trailer_pulling_out_of_field_onto_Trumpery_Lane_-_geograph.org.uk_-_1539487.jpg
But I don't know anything about the hitch, other than it is independent of the 3 point.
/ URGENT tow drop hook #9
I looked at a JD years ago when they were flooding the market with used European tractors. It had a mechanical tow hook that blocked the PTO when 'UP'. Didn't buy because of available parts, think that was why it was for sell. They seemed anxious to negotiate on it.
/ URGENT tow drop hook #10
well... if it is a hyd lift hook.. then it has a hyd cyl on it. if it has a cyl on it. follow the hose! The Hose HAS to go to a control valve SOMEWHERE!
/ URGENT tow drop hook #11
I believe it is called a "clevis hitch",a common european tractor quick release hitch. But I don't know where the controls are.
/ URGENT tow drop hook #12
URGENT must have figured something out by now.
Jim
/ URGENT tow drop hook #13
Maybee he followed the hoses to the control valve? ;)
many thanks all,it is a european model and it is different to the US models,we have a hook for towing trailers just below the drive shaft.
ive got it sorted ,a cable from the cab just behind the drivers seat to the right was missing.
THANKS ALL
Neil
/ URGENT tow drop hook #15
The hitch you are referring to is a pick up hitch, the hitch picks the trailer tongue up, they are extremely popular in the UK and are non existent in the USA. Some of these where actuated off of the rear three point of the tractor, when the 3pt was down the hitch was also down. However you could disconnect the hitch and pin it up, perhaps yours needs connected to the rock shaft on the 3 point? Other units used a separate hydraulic cylinder and valve to control the hitch, however this was more common on the larger tractors.
Sportsman your smack on,we have a seperate cylinder on ours,got it working .
Thanks for all the help.
neil
2020 International LT625 48" Sleeper (A62613)
2020 International...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
New Holland T5070 (A64126)
New Holland T5070...
