Universal Quick Attach Bucket Dropped on Both Feet
   / Universal Quick Attach Bucket Dropped on Both Feet #31
I'm not familiar with the JD design. I thought they all adopted the SSQA
I also see the cheap online adapters that look like junk flimsy junk
On the JDQA the lower part of the base just has two 1 inch holes, the upper part casting where the bucket cylinders attach is a rounded bar. The bucket has curved hooks facing back those bars fit into, the lower part of the bucket has two pins sticking straight back. You pull up to the bucket with the cylinders extended and the bars fit snugly in the hooks, lift and curl the bucket back and the pins slide into the holes and then all you do is put the lynch pins into the small holes in the bucket pins.
   / Universal Quick Attach Bucket Dropped on Both Feet #32
The JD design is far superior to the skidsteer quick attach for low lift capacity loaders. It keeps the bucket in close to the lift pins, saving the limited lift capacity. However it has some design limitations as well. When back dragging the weight is on two small pins that have holes drilled in them. The limited capacity and low traction force of the tractor generally prevent damage, however a stronger tractor could cause the mounting pin to break. Also wear in the mounting pin can degrade its strength and can break if enough use is put on it. Replacement is cutting and welding a new one on.
The skidsteer quick attach is a much more durable bucket attachment system. However it sacrifices some lift capacity due to the minimum depth of the latches. On a small sub compact this reduction can be noticeable. The locking pins can break but it is easily replaced with basic hand tools.
Both have their place. But on mid sized compacts and larger I prefer the skidsteer quick attach.
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
2020 DRAGON ESP...
Case 870 Agri King Loader Tractor (A59814)
Case 870 Agri King...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
Can-Am Defender 11000 (A59814)
Can-Am Defender...
1605 (A57192)
1605 (A57192)
