u joint availability
/ u joint availability #1
99yanmar
Wausau Wisconsin
1999 Yanmar F250 1981 Case 580D tractor backhoe
I have a yanmar tiller that has a quick attach bracket which couples my pto to the tiller,the problem is my u joints are worn out.I believe ther metric and can find them locally[central wisconsin]Where can I get Yanmar Parts?
/ u joint availability #2
Others may on here may have them . Or, you can call fredricks at (256) 773-9951. I know he imports these tillers and may have the parts you need....Or, Danny parker (205) 646-3033 may be able to get you the parts
/ u joint availability #5
We have about 25 of the shafts on a pallet, mostly the male ends.
Why is it everyone breaks the female end of those things ??
Ernie
/ u joint availability #6
I had to replace the u-joints in my shaft and had the same problem. Ultimatly, I was able to get a set close (but not right) from Baum Hydraulics. Before calling them, take your old joints apart and mic them. They will need these dimensions. I found a set that was close, but the width was just a bit too much. I couldn't get the C clip back in. I ended up grinding a small amount of material off the cross below each cup and that did the trick. I don't use the tiller very much, but it's been togther and through several gardens now with no problems.
Remember guys: These tiller are really cheap, but they're worthless with out that driveshaft! If you are getting a tiller, make sure it comes with the correct shaft and the joints are tight!
/ u joint availability #7
If you don't want to get an a assembly from Ernie then,
Just take the assembly to a drive shaft shop and they will match up and repair.
These usually break from tilling too deep, this creates a sharp angle on the u-joint and something has to give ( don't ask how I know this).
Container (A61572)
Container (A61572)
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A61573)
2019 Chevrolet...
2017 Toyota Tundra 4x4 Crew Cab Pickup Truck (A61573)
2017 Toyota Tundra...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
2025 Auger Bit Skid Steer Attachment (A61572)
2025 Auger Bit...
8' DISC HARROW (A60430)
8' DISC HARROW...
