u joint availability
/ u joint availability #1
99yanmar
Wausau Wisconsin
1999 Yanmar F250 1981 Case 580D tractor backhoe
I have a yanmar tiller that has a quick attach bracket which couples my pto to the tiller,the problem is my u joints are worn out.I believe ther metric and can find them locally[central wisconsin]Where can I get Yanmar Parts?
/ u joint availability #2
Others may on here may have them . Or, you can call fredricks at (256) 773-9951. I know he imports these tillers and may have the parts you need....Or, Danny parker (205) 646-3033 may be able to get you the parts
/ u joint availability #5
We have about 25 of the shafts on a pallet, mostly the male ends.
Why is it everyone breaks the female end of those things ??
Ernie
/ u joint availability #6
I had to replace the u-joints in my shaft and had the same problem. Ultimatly, I was able to get a set close (but not right) from Baum Hydraulics. Before calling them, take your old joints apart and mic them. They will need these dimensions. I found a set that was close, but the width was just a bit too much. I couldn't get the C clip back in. I ended up grinding a small amount of material off the cross below each cup and that did the trick. I don't use the tiller very much, but it's been togther and through several gardens now with no problems.
Remember guys: These tiller are really cheap, but they're worthless with out that driveshaft! If you are getting a tiller, make sure it comes with the correct shaft and the joints are tight!
/ u joint availability #7
If you don't want to get an a assembly from Ernie then,
Just take the assembly to a drive shaft shop and they will match up and repair.
These usually break from tilling too deep, this creates a sharp angle on the u-joint and something has to give ( don't ask how I know this).
2022 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2022 ASV RT-25...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
213088 (A64276)
213088 (A64276)
Invoices (A63117)
Invoices (A63117)
