tym
Attach some pictures of your tractor and some of the specs that you know on the tractor, and maybe some of us can come up with the TYM or Mahindra model that compares with it. I'll help you if I can.
Galen LaWall
Your Mahindra Tractor Dealer
Batavia, NY 14020
585-343-0770
rlee6
Other than the Mitsu engine I believe it is the same as the 330HST (TYM) or the 3510HST (Mahindra) Give AmJawa a call (888-357-5105) and ask for Chad. Explain your situation and he should be able to help you or put you in touch with a dealer that can help. AmJawa may or may not yet have all the parts yet but they are on the way. Feel free to tell him to call Jay if he has any questions you cannot answer. He has my number.
Happy Tractoring
Chipperman /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
LaWalls Tractor and Chipperman:
I don't have the tractor with me now. I will take some pictures this weekend when I pick it up from the seller's yard.
Here is the specification for Allmand 8435 HST:
Engine: Mitsubishi S4L2 36 hp 4 cylinders (different from TYM 330 HST or Mahindra 3510 HST)
Drive train: HST 3 range, MFWD, Differential lock, Wet disk brake, Hydrostatic steering
PTO: independent, electro-hydraulic, 540 rpm @2775 rpm (rear), 2000 rpm @2650 rpm (mid)
Hydraulics: open center, 6.3 gpm main, 4.5 gpm steering
3ph: position control, 2080 lb @ lift point, 1200 lb @ 23" behind lift point
Length: 114"
Width: 52"
Height: 93"
Wheel base: 66"
Min ground clearance: 14.6"
Weight: 3064 lbs
Hydrostatic pump: Eaton 77122RAA
The folks at Allmand mentioned certain models of TYM and Mahindra are same but could not give me specific model numbers. Are TYM T330 HST and Mahindra 3510 HST basically the same machine?
What I really need now is the list of filters, if possible, with part numbers. Since this is an oddball tractor, I want to acquire as much maintenance information as I can. Thanks for the lead, Chipperman. I will call him tomorrow.
</font><font color="blue" class="small">( Are TYM T330 HST and Mahindra 3510 HST basically the same machine? )</font> The only major difference is the motor, Tym uses a Kubota motor and I believe that Mahindra uses a Daedong , Both are good motors. The mitsibishi S4L2 is also used on a couple of Montana and Farmtrac compact models so parts support and filters will be readily available
/ tym
yes they r.
give amajaw a call they got me my parts in a timely manner
Thank you gentlemen for the replies. Last Tuesday I went to a local auction (I said to DW that I would just to watch) and bought this tractor. I used all the right information I learned from TBN such as "no blue or white smoke" "no leaks" "running PTO" etc. It met all these criteria. But I knew nothing about discontinued brand or model.
I feel better now knowing that it can be serviced and parts are going to be available in the future (and even phone numbers for parts and maintenance info). Thank you all.
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
2025 30in. Pallet Forks and Frame Skid Steer Attachment (A59228)
2025 30in. Pallet...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A59230)
2004 Pierce Tilt...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
ROSCO SPR-H CHIP SPREADER (A59823)
ROSCO SPR-H CHIP...
