Ownership likes and dislikes
   / Ownership likes and dislikes #21
T255:
The only "issue", front end loader has no proportional control, with a bucket it is acceptable but with forks it can be a nightmare.
rear remote does acting " weird" from time to time.
anoying issues:
bucket and forks are not 100% straight anymore, and i'm not a hard user at all !! But the buket and forks are still good enough to use. Pretty sure other people would say, "they are still straight" ;-)
Engine Oil dipstick accessibility is terrible
gearbox/ hydraulic breather rubber siphon thing is sheap
For the rest so far, nice and fun little tractor
The hydraulic pump has an output of 5-gpm, at redline of the engine. The smallest loader control valves I have found are rated for 11-gpm. So, they are twice as large as the SCUTs need, but I haven't found a loader valve that is rated for 5 to 7-gpm yet. So, you have full pump flow at about a third of the loader valve movements. Couple this with the small cylinders on the FEL, and it takes a very fine hand to feather the valve. I've considered adding restriction valves in the hydraulics to the FEL to make them less responsive and slow them down.
   / Ownership likes and dislikes #22
Yes, i'm looking into another control valve or adjustable flow control valves as well.
   / Ownership likes and dislikes #23
My T224 lists the "implement pump capacity" at 4.17GPM and "steering pump capacity" at 2.11GPM, yet a max total flow at 6.97. Must be that last 0.69gpm is for the 3-pt or is it Korean math.. lol
Here's the loader valve on my T224. I couldn't find anything on it w/ a search on the Google machine..
   / Ownership likes and dislikes #24
Love my T25. I've got just shy of 150 hours on it without so much as a hiccup. Based on what I've read on this thread, maybe I've been lucky, or maybe the T25 is just a better built model in the TYM lineup.
   / Ownership likes and dislikes #26
Sometimes you have to dig into the details of why someone is upset.
I spent about 8 years of my life doing tech support for computers. When people have a problem, they often have a solution in their head and don't want to hear about other solutions. This tends to make them unhappy if their preference isn't met. Sometimes people have a minor cosmetic issue and want a new machine. Sometimes they misuse something and want it covered under warranty. Even when the company steps up and replaces the whole machine, the same operator error exists.
I have had my T574H for 2 years. Never has it given me a lick of trouble.
   / Ownership likes and dislikes #27
I purchased a 2024 T754C in June 2025 and only have about 120 hours on it so far.
I don't like that there are no gauges except RPM, There is an aftermarket gauge you can add for coolant temp (and some other functions) which I do plan to add soon.
It has been used to pull a 15' batwing, 6' box blade, 8' rock rake, used it with a EA Wicked 60" grapple and it has done everything easily!
The A/C did have some issues keeping the cab cool with the extreme high temps in July/August. The dealer checked it twice under warranty and didn't find anything wrong, so I am considering getting the windows tinted.
The other thing they didn't do well is the thumb screws to remove the screen in front of the radiator for cleaning is right under a hose and is a pain to remove. My LS MT240 has it at the upper corner and is super easy to use.
Otherwise I have been very happy with the T754C and it doesn't seem to use a lot of diesel for a 74hp tractor
   / Ownership likes and dislikes #28
TYM was #2 on my list second only to the Yanmar iHMT transmission of the YT347 we ended up getting. I would buy a TYM though.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
Jumper Cables (A57149)
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
2023 54in Hooklift Dumpster 15 Cubic Yard (A56858)
2023 54in Hooklift...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A56858)
2013 International...
