TYM 654 dashboard
/ TYM 654 dashboard #1
steve tym
Platinum Member
TYM
Questions about my dash.
I have no temp gauge, should I?
All my idiot lights come on when I cycle the key, but none ever come on during operation. Glow plugs at start up, pto, 4 wheel drive, anything else that might come on during operation.
No speedometer.
No forward reverse indicator.
/ TYM 654 dashboard #2
Some TYMs had temp gauges while others didn’t. Don’t know why or when. But if it was me, I would be adding a aftermarket mechanical temp gauge.
/ TYM 654 dashboard #3
I asked the dealer about that last week
He said even the new ones don’t have a temp gauge.
Guess they figure we are not really going to work our tractor.
Adding one won’t be easy unless you put a pipe in your radiator hose. No port to be found on motor.
My speed sensor went out about 700hours the F and R still working
Probably a sensor.
I just live with that.
Right now I have bigger problems.
Contact your dealership about the speed sensor and let us know how that goes
Good Luck
/ TYM 654 dashboard
I mentioned it to the dealer, they said everything was normal.
Do you guys have glow plug lights that come on?
4 wheel drive indicator lights?
/ TYM 654 dashboard
Any input?
/ TYM 654 dashboard #6
I find that a visible temp gauge is a necessity especially when I am mowing fields that will clog my radiator with chafe
I eye that gauge at least once or twice a minute
I’ve overheated a few times and it goes from ok to overheated very fast
If it where me I would find some way to install a temp gauge
/ TYM 654 dashboard #7
I have glow plug lights on my 574. I'd have to look again to tell you what else is there. They come on briefly at startup and that's it.
I'll overheat before the tractor does...:)
I'm not earning a living with mine, though.
/ TYM 654 dashboard
I think I found a solution to the temp gauge. Hank Hamilton (you tube) did a clip where he installed an electrical temp gauge. I've got the parts on order. Will report back when I get it installed. Looked like a nice clean install.
/ TYM 654 dashboard #9
Sounds good. I'll be waiting to see and hear the results of the add-on gauge. It's good to have a visible gauge for temperature. Like Willman said, my gauge stays low mostly - but when it decides to climb it does it "right now"!
/ TYM 654 dashboard
Done. Now I have engine temp and % of load. It's sounding like loading a diesel is more important than high rpm. This plugs into a factory plug that I expect is for OBD.
2025 DELCO T/A 24FT GOOSENECK TILT DECK TRAILER (A59914)
2025 DELCO T/A...
12ft. Field Cultivator (A65640)
12ft. Field...
42" Hydraulic Smooth Lip Swivel Bucket (A62679)
42" Hydraulic...
JOHN DEERE 220 - 18' DISC HARROW (A64277)
JOHN DEERE 220 -...
2022 EZ-GO ELITE...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
