two position dump problem
/ two position dump problem #1
NevadaSmith
Northern Nevada
Kioti CK25
My owners manual states that there are two positioins for dumping the FEL on the joystick. By pushing thru a "feel" position, it dumps faster. However, on my CK25 I push the joystick to the right and it dumps and pushing past the "feel" it rolls back instead of dumping faster. I don't see how the "plumbing" can be bad with only 4 lines and all other things work fine. Is this a mis-print in the manual maybe?
TIA
/ two position dump problem #2
Something is wrong !!
I don't know what it is, but I do know the bucket rolling back when on fast dump is wrong.
Possibly a problem in the control valve itself.
/ two position dump problem #3
I can't imagine it working this way under any circumstances. If you're pushing to the right, and it starts to dump, then pushing further right should slightly speed up the dumping.
The only way I could see that it would roll back is if it happened with any right hand push, and that would mean the hoses are installed to the wrong connectors.
Ensure that you have the proper functions with each joystick location. Forward is down, backward is up, left is curl/rollback, and right is dump. If any of these don't operate this way, switch the quick connects around to get the proper function.
Make sure you turn off the tractor and move the joystick all around to release all pressure before disconnecting the hoses.
Pull back on the collar of the quick connect to release it and put it back on. Make sure that each QC clicks in when you replace it, and pull back on it to ensure that it's fully engaged.
John
everything works as it should...just this one position seems backwards.
Thanks for the info everyone...I will call my dealer and have him look at it for my 50hr service (almost there!)
/ two position dump problem #5
<font color="blue">By pushing thru a "feel" position, it dumps faster. However, on my CK25 I push the joystick to the right and it dumps and pushing past the "feel" it rolls back instead of dumping faster. </font>
hmmmm.... How does the 'fast dump' react if you have a heavy load in the bucket?
Don
/ two position dump problem #6
Sounds like you have a hyd line that has been installed improperly, or you need to check all your hyd quick couplers. Just un-pop them and put them back in. We have seen some weird things when couplers are not seated all the way. Check that and get back with us.
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
1500 GAL WATER TANK (A68842)
1500 GAL WATER...
DRAGON 500BBL WHEELED FRAC TANK (A67714)
DRAGON 500BBL...
2017 CATERPILLAR 249D SKID STEER (A65056)
2017 CATERPILLAR...
2014 Chevrolet Tahoe SUV (A64557)
2014 Chevrolet...
2019 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A69167)
2019 HINO 268 4X2...
