Trimmer recommendation? Stihl? Echo? something else....
/ Trimmer recommendation? Stihl? Echo? something else.... #81
Stihl or husqvarna would be my choices for battery operated..
Any particular model number (s) for either of these brands?
Also, what sort of minimum specs should I look for e.g. 40v, 80v, what cutting swath should be the minimum, I presume the minimum string length should be higher e.g 0.09 or something?
These specs will really help us narrow down on a model.
Thank you
/ Trimmer recommendation? Stihl? Echo? something else.... #83
Thank you I will look into these models and any others that may be recommended
/ Trimmer recommendation? Stihl? Echo? something else.... #85
Quick update, just to try it out, since it was on sale, we purchased a Black and Decker 40v trimmer and blower combo. The trimmer model is LST140 40V MAX* String Trimmer/Edger. It is a very basic trimmer, 40v battery, 1.5 amp, 13 inch cutting swath, line diameter 0.065in and 6.4lbs.
Sadly it stopped working after a few tries (it just clicks when we pull the trigger, so it will go for a refund or replacement).
We like the battery powered option because it is easy to start, especially for the older or less strong family members.
We want to purchase a 'real' battery operated which is stronger and can cut through the thicker weeds we have.
Which in your opinion, especially @girlwhowantstractor is a great strong battery operated trimmer, with a good warranty?? Please please please
Thank you!
I have no experience with Stihl battery-operated (plenty with their gassers). Some with Husqvarna....my old stuff I love; my new stuff I hate. I'm just one opinion here.
I came out strong for the Dewalt because it has exceeded my wildest expectations from battery-operated tools, of which I have owned a few over the years. I'm fussy about my tools (and frankly, everything). I always see where things could be better. I even pick apart my new tractor. :)
My Black and Decker battery trimmer is several years old, and only around an 18 v. Still running strong, and useful for small quick jobs, but nowhere near the power of the Dewalt, as expected. Perhaps, as often happens, B&D has experienced a reduction in quality recently. IMO overgeneralizations about brands are no good any more. A brand /model is great for a few years, then not.
My Dewalt stuff was bought in the last few months, so I think I can recommend these particular models with some confidence. My only gripe (and I will always have some :) ) is the lack of harness. Bought one third-party. Truly a monster. So powerful, it even digs. :)
I will say about the B&D trimmer, with mine it is tricky to fully engage the battery. I really have to slam it home. Yours SHOULD have a button you can push to show battery strength, so check that.
/ Trimmer recommendation? Stihl? Echo? something else.... #86
Thank you!
Remember - when you get in to "battery operated" tools you are buying into a "system".
My tractors, truck, van, VW TDI all run on diesel. My "small engines" - Honda civic, lawnmowers, trimmers run on gasoline or gas/oil mix. So that's two "systems" I maintain.
My really small engines/motors run on electricity, mostly corded. But it's getting so there is a lot of crossover between tools that run on small gas or gas/oil and tools that run on battery alone. But running on battery can require a unique battery and charger. Or not.
I've about settled on the DeWalt 20V max/FlexVolt line. I've over a dozen tools, and several flashlights that use the 20V max batteries, and just bought a trimmer that uses the Flexvolt (flexvolt batteries work on most 20V max tools, 20V max batteries DO NOT work on flexvolt tools). It is very handy to be able to swap in batteries.
So when choosing a battery operated trimmer consider what other tools will use the same battery.
Also, I'm impressed with my DeWalt Flexvolt trimmer, but have only run it for about 15 minutes (got it last night).
/ Trimmer recommendation? Stihl? Echo? something else.... #87
I bought my first Echo toll without much research as I needed it NOW for business use. Bought it from Home Depot and picked this particular blower because of the specifically stated part about a warrant for being sure to start. That was over ten years ago and it still starts reasonable easy with mixed gas over two years old. This caused me to purchase an Echo for my next trimmer and recently a chain saw after being a satisfied Husky owner for many years. That had a couple of "getting familiar" issues and now I'm definitely impressed with all three tools.
A belated Happy Holidays and Happy New Year to all of you.
After some discussion over the break, we decided that maybe we need one strong, commercial grade or near commercial grade Gasoline trimmer as a replacement to the heavy duty homeowners one we have now, which is regularly breaking down.
If we are ok spending about $300-400 or so, which brand/model (Gasoline) do you recommend?
We want a unit that has a good warranty, good quality (not breaking down every few weeks) and can take a thicker diameter string?
Shindaiwa? Echo? Stihl? Honda?
Please advise!!!
Thank you
/ Trimmer recommendation? Stihl? Echo? something else.... #89
And a Happy New Year to you too. I can't remember if I've already advised you on what I have but, I have a Stihl FS85 = 2-stroke, straight shaft, 'bicycle handle', with a chest harness. It came with an interchangeable tri-blade cutter which I use on thick vegetation and 'woody' ferns (bracken).
Thick & woody vegetation will eat trimmer string for breakfast.
I've had flawless operation for the past 4 years of operation. The 'bicycle handle' & chest harness eliminates harmful/painful vibration to your hands + is less exhausting during prolonged operation. IMHO.
/ Trimmer recommendation? Stihl? Echo? something else.... #90
I've had very good luck with Echo, the oldest I have is a handheld blower that's probably about 30years old. I also have a PAS 266 trimmer, it does great although in heavy vegetation I wish I had gone with the 280.
My large backpack blower is 2 pull cold and 1 pull once it's been started for the day, love it, it's about a 5year old PB770. The trimmer is a little more temperamental when cold but still starts easy, although there is some adjustment to the carb so I'm sure I can fatten it up a little.
Nothing wrong with Stihl but I've had more issues from them, just had to disassemble my dads BG86 the other day because a front cover bolt backed out and jammed into the flywheel. He's lost a number of bolts from backing out, well maintained but seems to be a little more "attention" then the Echo's. Same for some other Stihls I've been around in the past.
2014 Timpte Hopper Bottom (A61307)
2014 Timpte Hopper...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A60352)
2004 International...
CFG Industrial MH12RX (A60463)
CFG Industrial...
2025 MMS MS36CJ (A60463)
2025 MMS MS36CJ...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
