Hello,
I've got a bit of a problem with a tree spade, and am looking for help.
I've got a Vermeer TS-30 tree spade (tractor-mounted version) that I hook up to my Deere 4020. It's probably 50 or more years old.
The problem is that when I use it, the hydraulics on the tree spade act funny. I engage the hydraulic pump on the tractor, and then can use the tree spade with no issues. When I disengage the pump on the tractor, often the hydraulic valve levers on the tree spade start slowly moving on their own (causing the various spade functions to engage; the spades open, the tilt engages, etc.), AND I get a bunch of hydraulic fluid leaking from the valves and running everywhere. Obviously this is not ideal. This is not new behavior, it has always done this (I've just put up with the bad behavior, but I need to fix it).
I have recently discovered that the tree spade is set up for open-center hydraulics and my tractor is closed-center. There is a plug to convert from open-center to closed-center, but I don't have the plug, Vermeer doesn't sell it anymore, and the original hydraulic supplier ("Energy") hasn't made this valve block in 40 years. From what I can tell, the plugs made for this type of conversion aren't universal, so I can't make one from another hydraulic manufacturer work. Our local welding shop 3D printed a rubber plug for me to try, but when I used it today, it still had the bad behavior. I know the problem is with the tree spade, because the tractor hydraulics work fine on other implements.
My questions:
1) Is what I'm seeing (valve levers moving and leaking hydraulic fluid) consistent with running open center hydraulics on a closed-center tractor? Or is something else going on? If I fix that problem, will it be resolved, or am I chasing the wrong cause to my issue?
2) Long-shot... does anyone know where I can find the plug to convert this system to run on CC hydraulics?
Thanks in advance for the help!
My questions:
