Tree hogging with a CUT
/ Tree hogging with a CUT
barneyrb said:
We have what I think is a Brown Tree Cutter at our camp. It has 4 blades and will cut ANYTHING up to about 12". It is bad for cutting a sweet gum thicket. Brown Mfg Corp - 2000 series Folding Deck Tree Cutter
Barney, That is a slick machine! The website says to consult with the factory for use outside of the published HP ratings and the lowest rated unit they list is 50-90 HP SO...
Looks like that is a couple points scored for the bigger tractor guys. My Brush hog is rated for 80-85 HP (don't recall which) but it dopes pretty good with 39. For tree cutting duty it would probably be a good thing to make their minimum suggested HP (50 HP for the smallest unit.)
With a unit like that optimized for tree cutting and the right sized tractor I'd be the brush-tree killer from Hades!!!
Can't have a post with HE double toothpicks in it or it is replaced with **** but Hades posts just fine!
Pat
/ Tree hogging with a CUT #23
Yeah, we run it on a 55hp tractor. You back into everything and the top bar is spring loaded to retract when pressure is applied. The 4 blades obviously swivel and are around .750 thick. Each blade has the opposite bevel and when it hits a tree it acts like an axe alternating angle blows. It will throw chips about as big as a deck of cards. I'm telling ya it is wicked.
/ Tree hogging with a CUT #24
Pat,
I am surprised you haven't seen more of those tree cutters. I saw my first one at an auction in your neck of the woods. Brinkley was selling a couple of them when I was out there last time. One sold for 1300 and I dropped out on the second at just over $2,000. Sure did want one, but figured I could build one from junk in the back yard cheaper than that.
David from jax
WHOA!!! Not only had I not seen one I was blissfully ignorant of their existence. Now it will eat on me that there is a CORRECT TOOL for doing what I am doing.
Oh, well. Maybe I can console myself that I will run out big stuff to cut down and it would not be reasonable to buy one.
Pat
/ Tree hogging with a CUT #26
They cleared the right of way for my powerline with something similar. Instead of blades and a stump jumper it has a big, thick steel disk with 4 short thick blades attached to the disk. The guy did not stop for ANYTHING! Rocks, stumps, tree trunks. It ate them all. Powdered a cinder block like it wasn't there.
My B-I-L's theory is that if his tractor can push it over, his 14' JD dual spindle can cut it up. I've seen him breeze through 5" pines.
I have a light duty mower. I solve my tree problems with the FEL. It truly solves them once and for all.
This is a picture out front of my cabin. Our pond is way down below. It is like two terraces (hills) down to the lake and the cleared area is about 2.5 acres total. It looked just like the pines on either side before I cleared it.
This is just to agree with Patricks point that these little machines can do a lot more than what the owners manual says. However, in both his case and mine, I feel pretty sure we're probably knocking off a few years of our tractor's lives. At least in my case, clearing those trees, stumps and rocks required the tractor to be used to its maximum both in terms of hp and hydraulics. So even though the machine can do it, I'm not sure I'd recommend it.
/ Tree hogging with a CUT #27
I have a 42 PTO hp machine and a medium duty cimmaron rotary cutter and I have used it for 3" trees and maybe a little bigger. I've never sharpened my blades in 3 years so it more or less breaks the trees apart than actually cutting them.
/ Tree hogging with a CUT #28
Here's one of my shredders. It's 5' and I pull it with a 24HP Hinomoto.
It will cut 2 to 3 in thick brush if I do it right. If I hit it with the FEL just right I end up with sticks that I toss into a brush pile for the little animals.
It could be used more effectively if I had more horsepower but I don't.
Nathan, I sharpened the blades (well didn't actually make them sharp just sort of made the leading edge of the blade's cutting zone thinner than the trailing edge) once in 5-6 years before a blade broke in half at the mounting hole and I bought a new pair. The cutting edge of the new ones got hammered flat fairly quick. My cutter is the 6 ft HD Cimmaron rated for either 80 or 85 PTO HP, I don't recall which.
I could never keep the pins on the mower that go into the lower arms of the 3PH tight. I used a 3/4 drive and cheater but they constantly loosened so I welded them. Lasted 3-4 years and the pin broke. I cut the required material out of the way with a plasma cutter and installed a new pin and tightened it with a longer cheater (4-5 ft) on the 3/4 drive breaker bar. It is holding so far but the pin bent with use.
Pat
/ Tree hogging with a CUT #30
Pat
Looking at your pictures, my mower looks basically the same except for all the extra bracing on the top of the deck. Mine has a couple pieces of angle iron and that's it.
I've never had an issue with the pins. I use a harbor frieght quick hitch but not sure if that would make any difference. I've pulled a pin off my tandem disc but never had an issue with the mower.
I couldn't find a good picture of it with my Kubota, but I did find this old picture of me using my Farmall M with it though! :D
/ Tree hogging with a CUT #31
I run a 5' Brown tree cutter w/ my 4720 Hydro and often go thru 8" pine or sweet gum trees. Have a FOPS and forestry cage to avoid damage to my soft head. My 5' model weighs in at 1600 lbs and is 20 yrs old. I drive over 4" trees thanks to my belly pan. The folding deck model is the way to go if you can afford the 9 K investment.
/ Tree hogging with a CUT #32
I've seen em at auction in person.pics don't do em justice. They look like super- bad-to-the-bone/Tractor breaker to me? I would guess a malfunction/lock-up on the clutches(misplaced/accident grease in the wrong place) would be a bad day even for a heathty tractor? thanks for the Info :)
/ Tree hogging with a CUT #33
I have also found out from experience it is a very good idea to have some protection from the flying debris, especially if you do not have a cab.
Stiff wire mesh or plexi attached to your ROPS can deflect flying chunks of wood and save your backside - even though a full cage would be ideal
Eye and head protection is also recommended if "chopping" in areas where larger trees exist, as material thrown from the hog can easily deflect off of these trees right back into the operator from many different angles.
/ Tree hogging with a CUT #34
Remembered to take some pictures of areas I'd bush hogged in the forest - you can see the sort of thing I'm cutting, and how the ground looks after
/ Tree hogging with a CUT #36
A little bigger than i like to go but the pics are first class!
AchingBack said:
Al Gore would be very proud of all you tree hoggers.
Is that the Al Gore that invented trees?
Pat
/ Tree hogging with a CUT #39
Pat
You know, its just so unfair that this always gets taken out of context. Al Gore never said he invented trees. What he said was that he helped pass legislation that made it possible for God to make the trees.
OK, was this the Al Gore who wrote the famous poem while serving in the armed forces...
I think that I shall never see a tree
quite so lovely, oh so lovely as ME!
This would have been after he invented water and before he invented the internet.
...and this just in... A late breaking flash announcement! Behavioral scientists have determined the reason Al Gore crossed the road. He wanted to see where the chicken went.
Various comments and relevant statements were issued by and political types.
HILLARY CLINTON:
When I was First Lady, I personally helped that little chicken to cross the road. This experience makes me uniquely qualified to ensure -- right from Day One! -- that every chicken in this country gets the chance it deserves to cross the road. But then, this really isn't about me.......
BARACK OBAMA:
The chicken crossed the road because it was time for a CHANGE! The chicken wanted CHANGE!
COLIN POWELL:
Now to the left of the screen, you can clearly see the satellite image of the chicken crossing the road...
ANDERSON COOPER - CNN:
We have reason to believe there is a chicken, but we have not yet been allowed to have access to the other side of the road.
JOHN KERRY:
Although I voted to let the chicken cross the road, I am now against it! It was the wrong road to cross, and I was misled about the chicken's intentions. I am not for it now, and will remain against it.
BILL CLINTON:
I did not cross the road with THAT chicken. What is your definition of chicken?
AL GORE:
I invented the chicken!
Pat
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
40' Used Container, High Cube, Single End Doors (A62679)
40' Used...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
2015 Chevrolet Silverado Pickup Truck (A62613)
2015 Chevrolet...
2010 Ford Crown Victoria (A61574)
2010 Ford Crown...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
