Transport Chain
/ Transport Chain #21
per my recent hoisting/lifting certification class.
A new rule (dont know how new but "new") is that all graded chain be stamped with the grade every 2-3 links.
for Grade 70 thats G70 or G7 stamped on the side of the link.
What grade is a fairly new 5/16 chain that has "PM" and "M3" stamped on it every 3-4 links? Thanks....
/ Transport Chain #23
Over 10K it must be chains.
I dont think this is true. Where I work (large corporation) we receive aluminum coils in on flatbed trucks. Usually 3 at a time and the weights are anywhere from 12k-16k lbs. They use straps.
Bigger is not always better. I compared the working load limits table for each grade
For 5/16" chain
Grade 43 - 3,900 pounds
Grade 70 - 4,700
Grade 80 - 4,500
Grade 100 - 5,700
For 3/8" chain
Grade 43 - 5,400 pounds
Grade 70 - 6,600
Grade 80 - 7,100
Grade 100 - 8,800
It would seem you are wasting money to step up to 5/16" Grade 80.
Not really. Grade 80 has a higher safety margin since it is certified for overhead lifting. The chain is actually stronger. So if you are lifting, it certainly isnt a waste of money considering the hefty fines and lawsuits associated if something went wrong.
But for strapping a light load to a trailer, yea, probabally a waste of money.
I always use GR70. Note the 5/16" GR70 is stronger (and lighter and easier to handle) than 3/8 GR43 and the price is about the same.
Better double check that statement.
/ Transport Chain #24
Friday morning I was headed to my place in Centerville, about 140 miles from my main residence. As I was driving through Houston, a DOT / Commercial Truck Enforcement cop pulled me over. After asking if I was for hire, and me instructing him that I was not a commercial load, he said I had no problems. I took the opportunity to ask him a few questions...
First, I have a GN ball in the truck, but no safety chain tie down points. He said I did not need them as I was exempt being a farm load. He did recommend attaching the break a way cable to something, as a DPS trooper might cite me for that.
Second, I had him look at how the load was secured. He looked at the ratings on the straps, 3300# each, then said I was fine for a non commercial/in-state load. Said if I was commercial, I would have needed to be secured on all four corners of each vehicle, and a strap on the loader, unless it had a lockout device.
He told me that the 8 weeks he was in the commercial enforcement class, the instructors really drilled into them not to mess with the farmers.:thumbsup:
Here's a pic of the load for reference.
The tractor had a strap over the rear 3pt arms, in front of the box blade. Also a strap running through the tube in the loader frame.
/ Transport Chain #25
That load would be placed out of service 9 times out of 10 in New York State. Private, commercial, farm, city wouldn't mean squat.
/ Transport Chain #26
Sure glad I am in Texas:D
To be honest, I don't fully understand why the regulations are different for farmers vs commercial loads, but I am glad that I keep farm tags on my larger trailers for that reason.
/ Transport Chain #27
I hate to say it but in Indiana it would pass if not pulled over. If pulled over the over 3 point arms would not fly. They would not cite you but would make you secure it on all four corners.
Chris
/ Transport Chain #28
I have chain that I took off of a hoist that is marked "H" on the links. What's do the letters mean?
We still need some help trying to interpret chain grade codes....Anybody....thanks.:confused:
/ Transport Chain #30
Known Chain and Hook Markings Grades Chain Markings Hook Markings
Proof Coil Grade-30 G3, G30, C3, M3, 3, Npc, C, 30, Canada, L, M, P, PC. C.
High Test, Grade-43 G4, G40, G43, 4, 43, 430, HT, C4, M4, MHT, H, High Test, Canada, Canada 4, L, M, P, W, PH. H, HT, High Test, G4, G40, G43.
Transport Grade-70 G7, G70, C7, 7, 70, 700, CM-USA, M7, L, P, TS, W. Transport 7, 70, T7, G7, G70, S7.
Alloy Grade-80 A, T, G80, 80, 800, C8, 8, A8A, CA8, HA 800, CM-USA, L, P, TS, W. A, AA, AL, Alloy, 4A, A8, C8, Kuplex, Herc, P8, T80.
Alloy Grade-100 nil nil
/ Transport Chain #31
Thanks, davkir and ramheadjim. Those sites were interesting reading. Guess my pile of chain is general purpose Proof Coil....good enough for working around my place and tie down for my little BX tractor. :thumbsup: I probably bought it at Lowe's several years ago vs getting a heavier grade at a tractor or trailer business.
/ Transport Chain #32
A loose load from a farmer/hobbyist/homeowner could kill someone just as easy....don't see why a farmer should have looser tiedown regs...:confused:
2014 Bobcat E63 (A64126)
2014 Bobcat E63...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
JCB 92" Clamshell Bucket (A64119)
JCB 92" Clamshell...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
UNUSED KIVEL 48" PALLET FORKS (A64280)
UNUSED KIVEL 48"...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
