Transport Chain
/ Transport Chain #1
strum456
Westmoreland County PA
Fords
What are the DOT requirements for chaining down non-commercial loads?
Is a certain grade of chain required no matter what (such as grade 70)?
Is it legal to use grade 43 chain, as long as the load is within the working limits of the chain being used?
Can the total weight of the load be divided by the number of chains holding down the load to determine the chain strength needed? Or does each chain need to be rated equal or more than the total load?
/ Transport Chain #2
In general none really till something goes wrong. For loads less than 10K in the commercial world or non wheeled straps appropriately rated are fine. Over 10K it must be chains. No real rule on grade just that they are in good working order and rated for the load.
Chris
/ Transport Chain
Why is grade 70 chain commonly referred to as transport chain? I was inferring that g70 must be what some athority wants you to use. I guess that is not so, based on your anwer.
/ Transport Chain #4
Could not answer that. One difference is weight. G70 is much lighter per # of strength.
Chris
/ Transport Chain #5
Grade 70 is the most common chain used to secure loads. Transport chain is usually grade 70 or higher. If you are over 10K it should be grade 70 or higher. For lighter loads I have used grade 43 chain which was well within the working limits of the chain. Currently I used 5/16" grade 70 for anything I haul over 1000 lb. I also carry several lengths of 3/8" chain for backup. For loads under 1K I have used ratchet straps.
/ Transport Chain #6
The name comes from the National Association of Chain Manufacturers WELDED STEEL CHAIN SPECIFICATIONS which is referenced in the Federal Motor Carrier Safety Administration's Cargo Securement Rules. The Rules have requirements for tiedowns based on weight but do not require Grade 70 Transport chain as a minimum.
The grades are:
Grade 100 Alloy Chain Premium quality, highest strength alloy chain, heat treated, used in a variety of sling and tie down applications. For overhead lifting applications, only Alloy Chain should be used.
Grade 80 Alloy Chain Premium quality, high strength alloy chain, heat treated, used in a variety of sling and tie down applications. For overhead lifting applications, only Alloy Chain should be used.
Grade 70 Transport Chain A high quality, high strength carbon steel chain used for load securement. Not to be used in overhead lifting.
Grade 43 High Test Chain A carbon steel chain widely used in industry, construction, agricultural and lumbering operations. Not to be used in overhead lifting.
Grade 30 Proof Coil Chain General purpose, carbon steel chain. Used in a wide range of applications. Not to be used in overhead lifting.
Machine Chain Short pitch straight link or twist link, general utility chain made of carbon steel. Not to be used in overhead lifting.
Coil Chain Long pitch straight link or twist link, general utility chain made of carbon steel. Not to be used in overhead lifting.
Passing Link Chain Short, wide link chain which resists kinking or tangling, made of carbon steel. Not to be used in overhead lifting.
Stainless Steel Chain A corrosion-resistant chain manufactured from stainless steel, used in food processing, chemical, marine, and high temperature environments.
http://www.truckntow.com/productspecs/NACM_Welded_Specs.pdf
/ Transport Chain #7
Bigger is not always better. I compared the working load limits table for each grade
For 5/16" chain
Grade 43 - 3,900 pounds
Grade 70 - 4,700
Grade 80 - 4,500
Grade 100 - 5,700
For 3/8" chain
Grade 43 - 5,400 pounds
Grade 70 - 6,600
Grade 80 - 7,100
Grade 100 - 8,800
It would seem you are wasting money to step up to 5/16" Grade 80.
/ Transport Chain #8
Having towed much of the time (off and on) for a living since the early '60s I've always wondered about the term non commercial vs commercial.
I know how a load is chained/tied down to satisfiy DOT in the states around me so being curious I asked DOT if there is a different set of regs regarding non commercial . The answer was there is no difference regarding how a tractor is tied down if the rig has a DOT number and working for a living or just a private owner taking his 2000 lb or 12000 lb tractor to the repair shop or to do some work on another place for himself. The same tie down rules apply.
Now the question is what can we get by with when it comes to using straps or chain tie downs on wheeled vehicles. Your state DOT has the answer and having gone through as many different state scale houses as I have hauling my different type of wheeled construction equipment I wouldn't tell anyone what your DOT folks will say.
My tractor/FEL/7' mower or BB weighs around 7800 lbs and is always chained down at 4 cornors with 5/16 grade 80 alloy 5300 lb rated chain and hardware. My local DOT guy likes it.
/ Transport Chain #9
Chain is the only way to go for anything that moves. I even use chains on my ~800lb Rhino UTV. I have seen straps fail too many times. Also straps wear out fairly quickly if you use them a lot due to weather, fraying, nicks, etc. Chains and boomers last a long time.
I always use GR70. Note the 5/16" GR70 is stronger (and lighter and easier to handle) than 3/8 GR43 and the price is about the same.
If you are using a pickup to haul it and a chain on all four corners 5/16" GR70 should cover just about anything. I have equipment hauled on 18 wheelers all the time and they use 3/8 GR70 for pretty much anything. Personally I think the 3/8" is small when they are securing Dozers and such but that is what I have seen most of them use. Sure there are exceptions though.
/ Transport Chain #10
Cargo Securement Rules - Federal Motor Carrier Safety Administration
As far as I can tell a load does not know if it is a commercial load or a non-commercial load; when it breaks away it does not care and it kills, injures, or causes damage with no preference.
Note that the above rules state that UNMARKED rigging should be given a load rating equal to the lowest rating for rigging in that class. So unmarked 3/8 chain gets a rating the same as 3/8 Gr30 proof coil chain, even if what you paid for is Gr70 Transport chain.
Use of Unmarked Tiedowns
The new rules do not prohibit the use of unmarked tiedown devices. Although many of the participants in the public meetings and numerous commenters to the rulemaking proposal argued the rules should include such a prohibition, FMCSA believes it is inappropriate to prohibit unmarked tiedowns at this time. However, in view of the potential safety hazards of motor carriers misidentifying unmarked tiedowns, there is a provision that unmarked welded steel chain be considered to have a working load limit equal to that of grade 30 proof coil, and other types of unmarked tiedowns be considered to have a working load limit equal to the lowest rating for that type in the table of working load limits.
Secure your loads like you were a long haul trucker taking a stab at the NY to LA coast-to-coast time record in the middle of winter and you'll be fine. :)
A little extra rigging never hurt, but a little less can kill. :eek:
/ Transport Chain #11
Not using softeners with straps when and where needed is one of the causes for strap failures and accelerated wear.
/ Transport Chain #12
This is the most accurate DOT info posted so far.
Most important nugget is that DOT regs vary on the enforcement level based on who is doing the enforcing.
/ Transport Chain #13
uhh .. say what? The first thing that came to my mind is fabric softener..:laughing:
Do you mean corners protectors for the straps?
/ Transport Chain #14
Yes, they are referred to as softeners in rigging circles because they soften or ease a sharp corner which could cut or wear a synthetic or nylon sling. When you are hanging a chain fall say from a beam you put softeners on the sling to keep the edge of the steel from cutting the sling or to reduce the point load at the sharp bend in the sling. Same goes for choking a sling around a load with sharp corners. The sling would have to be severely de-rated to account for this condition, probably less than 50% of its stated capacity and maybe more.
http://www.csao.org/UploadFiles/Safety_Manual/Equipment/Rigging_Long.pdf
/ Transport Chain #15
We do that for overhead rigging chains, they have nylon or something around them like you described. I never understood what it was for, just kinda stay out of the way and let the riggers do their jobs and hope they don't let anything fall on me. :)
/ Transport Chain #16
I've used both Synthetic Slings and Straps plus Chains to secure loads for over 40+ years. The Synthetic Slings were used to lift cargo with my helicopters and the Straps and Chains to secure loads to trailers. My tractor is always secured with Grade 70 chains to my trailer if I have to move it. We learned a long time ago to protect Synthetic Slings and Straps with a length of fire hose surrounding the sling or strap on sharp corners no matter if it was being used to lift cargo or secure loads to trailers.
Jim
/ Transport Chain #17
per my recent hoisting/lifting certification class.
A new rule (dont know how new but "new") is that all graded chain be stamped with the grade every 2-3 links.
for Grade 70 thats G70 or G7 stamped on the side of the link.
/ Transport Chain #18
That probably came about as part of the overhaul of the cranes and rigging sections of the OSHA standards. Much of the rules comes from references to other standards from ANSI/ASTM or ASME to name just a few. Recent changes to the ANSI standards about rigging and rigging hardware require themto all be marked. Shackles and turnbuckles are two which need to be marked. Chain I believe also got the requirement.
/ Transport Chain #19
Regardless i was in Farm n Fleet the other day and stopped to look at, as i had rembered the tidbit from the class.... There grade 70 "gold" chain had G7 stamped in it. First time i had seen it.
/ Transport Chain #20
Think about it, guys. The only way to prove that any rigging or binding apparatus meets a regulatory spec is for it to be permanently labelled. Nothing new for grade 70 chain to be stamped in that manner; been that way for years. What might be new is that the chain being sold as grade 70 actually is.
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
Columbo Peanut Inverter Blades & Coulters (A64119)
Columbo Peanut...
2021 PETERBILT PB337DUMP TRUCK (A63276)
2021 PETERBILT...
2015 Caterpillar 308E (A64126)
2015 Caterpillar...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
