Transplanted Tree
/ Transplanted Tree #1
Tractors4u
Elite Member
Athens Alabama
Deere 4310, Kubota L355, John Deere SST18 Spin Steer, 2006 Polaris Ranger
I moved in to my new house February 25th 2006. I was mobilized with my National Guard unit on May 30th 2006. Needless to say I didn't get much done on the yard in those three months. Family vacation, job, building a barn and fence took up my free time. We are surrounded by trees but there are none in my yard. Being the inpatient type, I didn't really want to pay for a 5-6 ft tree and have to wait 20 to 30 years for it to get to a substanial size. I started scouting for trees on my property to relocate. After what I went through yesterday, I wish I had started smaller and worked my way up. It really didn't look that big untill I got it on the trailer. It is a 30 ft maple with probably 10" diameter trunk. Here is how I did it.
I started by digging down about 4.5 feet around the tree with my backhoe. It is a Koyker backhoe on a John Deere 4310 32hp tractor. I planned on digging around the tree, pulling the tree to one side, backing the trailer under the edge of the root ball and the pulling the root ball up on the trailer. I dug out around this tree about 2 weeks ago and then tested pulling on it with my truck, a Chevy 2500 diesel. It didn't budge. I then came up with a plan to use a cable to cut the dirt below the root ball. Loop the cable around and pull through. That didn't do squat. So I went back to just pulling. I pulled 4 or 5 times on that tree using a 10,000lb rated lifting strap and it didn't budge. On the 6th try the dirt broke free.
/ Transplanted Tree
After I had broke the root ball loose from the ground I leaned it back a bit away from the trailer and backed the trailer up to the ball and got the lip of the trailer just under the edge of the root ball.
My plan was to then use the tractor to pull the tree up on the trailer with the tractor. Yeah right, that was wishful thinking. I wish I still had my dozer. The tractor would budge it. I realized it was going to take about 3000 more pounds and 330 more HP. I unhooked the truck from the trailer and called a friend to bring his truck over to hook to the trailer.
/ Transplanted Tree
Well the extra weight and HP still wasn't enough to get that tree up on the trailer. We ended up leaning the tree over 90 degrees to the trailer and rolling the rootball up on the trailer. Just by accident, the straps ended up in a position where we could pull on the strap and it would roll the rootball on to the back of the trailer. Well we had to do a little restrapping. After we got the root ball on the trailer I used my tractors FEL to lift up on the trunk while my friend pulled the trailer out. There was a stump that the tree would have drug across and since we had yet to break a limb I didn't want to start now. That worked and we then used my truck to pull the tree all the way on to the trailer. Well, as much of it as would fit.
Once we go the tree on the trailer it was very tongue heavy. So heavy that the fender was 1/4 inch over the tires of the 4WD F150 pulling the trailer. We ended up hooking the trailer to my truck.
/ Transplanted Tree
I thought that this would be the easy part. I had pre-dug the hole before I got the tree there, but after actually using a measuring tape, I realized that the hole was a bit too small and shallow. I quickly dug it out and prepared to put it in the hole.
I pulled the trailer up so that the root ball on the trailer was lined up with the hole. I carefully put a around the trunk and below a couple or large, strong limbs. I attached the other end of the strap to my tractor and then set the break, put the outriggers down and put the FEL bucket down. I got back in the truck and pulled. The tree came off and no limbs broken. Me or the tree.
A gentle tug from the side and the root ball was in the hole.
/ Transplanted Tree
This is the part that got a little frustrating. I would pull and the tree would get about half way up and then fall over to the side. By this time my buddy had to go and I was working alone. I considered cutting it up for firewood until my dad came along. I had him get on the tractor and I started pulling with the truck and when it started going over he pull from the side with the tractor. I took us two tries to get the pulling angle just right. By this time it was dark and the rest of the work would have to wait until this afternoon. I cut a couple of T posts in half and used some ratchet straps to stabilize the tree. I am a little concerned about the strength of the straps so I may change them out. For now it seems solid. I backfilled with some very rich dirt from an area that was used to feed cows. A couple of perferated PVC pipes were put in to ensure that water got deep down to the roots.
The bad news is that I did lose one good sized limb, but it was an off shoot of another limb, so it didn't leave a hole.
The other part is that this tree was against another tree so it is somewhat flat on one side. Fortunately that side is facing the house so it looks nice from the front.
/ Transplanted Tree #6
A lot of inginuity goes a long way. Water the heck out of it and hopefully it will continue growing. Keep us posted..
/ Transplanted Tree #7
I agree with Johnk, I would water the heck out of that thing, set up a drip irrigation or something to keep the water getting deep on a consistent basis. I would also figure out some good fertilizer.
I don't mean to be a spoil sport, because I really hope it survives, but I know even with a big tree spade, trees that size are hard to keep alive.
Best of luck, it looks great, and your work was awesome.
/ Transplanted Tree
As I filled the hole in, I would dump the dirt in and completely saturate it with water. I did that with each load. Also the PVC pipes have holes drilled in the side and they go down to the bottom of the root ball. This first year will be critical. I want that big tree to make it for obvious reasons, but I also want it to live so that I don't have to deal with getting rid of it either!
/ Transplanted Tree #9
Out of curiosity, what would a tree company charge to do the work with a tree spade?
I give you credit for sticking with it and making the transplant happen; I doubt I would have been as persistent and as patient.
/ Transplanted Tree #10
Great job, sounds like a bit of perseverance paid off. I like the PVC pipe idea, and you are on the right track getting the water down to the base.
Sounds like you also did all you could do to eliminate air pockets so that is great and really helps the tree's survival
They also offer some root stimulators that you may want to consider, I think they are mostly intended for when the root ball is exposed, but with those pipes in, I wonder if you could inject them. I believe they are a mild acid to help root activity.
There are two camps on the tying and staking thing, many feel that staking and keeping it stable are very important, while some of the tree folks believe that allowing it to have some sway and room to move actually makes for a stronger tree. We usually try to not stake them, and then check them regularly (in your own yard I imagine that would be pretty easy :) ) Then we go back and stake if needed.
I hope it works well for you, that was an impressive root ball to handle manually, I liked the firewood comment, I think I would be thinking the same thing at some point in that operation, Then again, I may have just "blown in place" :)
/ Transplanted Tree
I have no idea what they would charge. My brother mentioned the same thing. My reply to him was, "where is the sport in that? That is like hunting on a baited field".
I am kind of a do it yourselfer. It was fun and if I had not being moving that tree I would have been watching TV. One day my kids will look back and say do you remember when dad moved that big tree? Then they will say, "boy was he stupid"
/ Transplanted Tree
That is interesting Alan, I thought staking was mandatory for a tree this big. I will do some research on it and see what I can find. My gut feeling is I need to keep this thing staked at least until we get through next spring. When it leafs out again and we go into windy March I don't want to take any chances.
/ Transplanted Tree #13
Great project and enjoyed the photos........however, I give that tree about a 25% chance of living. Sorry to sound negative about it, as I know you have high hopes and put in a great deal of work.
A tree spade (in our area) would have been about $400 to move it. Even then, you would have only had a 50-60% chance for success.
/ Transplanted Tree #14
I'd take some of the money you saved by doing it yourself and go buy you some more trees. Then this one will have some company. So what if it doesn't live, yank it out and put another in it's place. I wouldn't write it off so soon though, that may turn out to be the tree from hades, in a few years it'll be dropping leaves and limbs all over the place:D , but then that's just more seat time.
I think Don (txdon) transplanted one over at his place, don't think it was as big as yours, and haven't heard if it made it through the summer or not. Maybe he'll chime in.
/ Transplanted Tree #15
Wow, that was one heck of a transplant job. It's a beautiful tree and I could see why you'd want to transplant it so I too hope the tree makes it. Just out of curiosity, why not wait until the tree dropped it's leaves? From everything that I've heard, that would've been the best time to transplant and the tree would have been a whole lot lighter as well, right?
/ Transplanted Tree #16
Yeah, I'm a little curious about that too. I was always told to wait til almost all the leaves are off prior to transplanting. I had a maple tree moved not too long ago, when they were running sewer lines down the highway. I hardly got any leaves this year, but some of the material I read said it can take two years or longer to regrow. Good luck.
/ Transplanted Tree
I spoke with an arborist and he had advised this time of year. I sent hm the picture the other day. He didn't realize how big of a tree I was moving. He was a little surprised. I have another smaller, much smaller maple to check on this weekend and two small oaks, 6 and 10 feet.
I also plan on going to the nursery this weekend and getting some trees. Like I said in my first post, I wanted a big tree in the yard, one that looks like it has been there a while. If I had a bigger tractor and bigger trailer I would look for even bigger. I plan on working to keep this tree living. Hopefully this time next year I will give you guys a good report on Maple #1.
/ Transplanted Tree #18
you would be surprised at what a tree can take....sometimes. When we were clearing land for our house my father thought we needed a tree in a certain spot. He dug around a little maple with the back hoe and tied a chain around it, and drug if all the way to where he wanted it. By the time it got there there was no dirt left whatsoever on the root ball and the hole was too small so he just knocked it in and pressed it to fit with the hoe's bucket, covered the roots (crammed into a much smaller hole then needed) and called it done.
He never watered it or anything. It lost its leaves and didn't grow any the next year so I figured it was dead, but the second year it had a few leaves and the year after that it had a few more. It has been 5 years now and it is still a little scruffy but is much larger than when it was growing in it original spot.
Talk about the thing that just wouldn't die. I hope yours has the same tenacity.
/ Transplanted Tree #19
Brent, good luck with your tree. The conventional wisdom says that it has a slim chance, but then those guys at the convention all wear those funny hats. :D
I transplanted a (tiny by comparision) red bud a couple years ago, and it is doing wonderfully. I also just planted 5 large trees and a half dozen large shrubs from a nursery that I respect a bunch -- they are very knowledgeable tree people. According to them, you should NOT fertilize until spring. Water every 4 to 7 days -- a pencil sized flow of water for an hour and a half. That's for a 20 foot tall nursery tree, so you might want to go a couple hours. I used ABS perforated drain pipe to do the same thing you did -- get that water to the bottom of the root ball. Water weekly until the tree is completely dormant (leaves all gone, and then a few weeks after that), then start again next spring at the first sign of budding. Fertilize in the spring, and keep pouring the water to it on the weekly schedule.
The "$400" someone tossed out for a spade job is low for that sized tree. Most spade guys won't even take on the job of moving a tree that is in the wild -- they want to spade into that nice soft, often-worked, nursery soil. If it lives, you've saved yourself a couple thousand dollars, compared to buying a nursery tree and having it planted.
/ Transplanted Tree #20
My wife has a green thumb and one thing she throws into the mix on all transplants is Vitamin B-1.. I guess it helps roots take off....
