Trailer sway
/ Trailer sway
That is exactly how I had my tractor/loader/hog on the trailer the other day,it put too much weight on the back and not enough on the hitch thus causing my sway.If I make anymore trips I am going to have to unhook the brush hog and lift it into my truck bed,then I could distribute the weight on the trailer better by having the ability to move the tractor forward on the trailer and put more weight on the tongue.
/ Trailer sway #22
Scott,
If you try this without something else on the back of your tractor, you may still have a problem. Your profile doesn't say what tractor you have, but the other day I tried to lift my LP tiller out of my small utility trailer (much lower than a truck bed) without anything on the back of my JD 4400 and let's just say it was "exciting".
Hoss
/ Trailer sway #23
Naaaa. He said <A target="_blank" HREF=http://www.kansascas.com/images/Family_photos/truck2.jpg>TRUCK</A>/w3tcompact/icons/smile.gif
Hoss
/ Trailer sway #26
Shoulda bought the rest of the bed while you were at it........
Saaaaay What? That's as long as they come! Full 8'
Hoss
/ Trailer sway #28
Ooh yeah! Pictures of Super Duty's. That's what I like to see.
Hoss and Inspector, you've both got nice looking trucks.
I'll add mine to the mix. It's a '99 PSD.
--Brad
/ Trailer sway
Nice rig Hoss,thats what I need...
I have seen a new Ford ( 6000?) around my town that has duals on it 4x4 and a regular pick up bed on it with extended cab,nice looking truck...looks like I would need a ladder to get in it.I don't ever remember seeing that heavy of a truck with a pickup bed on it...
/ Trailer sway #30
Do you guys have a problem with the caps lock on your key boards? Seems like when ever you type "truck" it comes caps /w3tcompact/icons/tongue.gif. I guess I'm out numbered... no other Chevy's out there... Help!
Actually I have no preference. Attached is a picture of our wrecker it also has a 9' plow for winter. It was the last year they made the old body style, which I like better than the new Ford or Chevy. Ended with the Chevy due to some problems that Ford would not take care of because they claim it is a commercial use and voided warranty, that's a story all on its own. Then some stuff happened after warranty that just shouldn't be with a truck like that. So went with a Chevy, dealer was closer and better managed. We'll see if the Chevy can take it. We plow 100 commercial driveways in the mountains. One winter behind with no problems, we will see what happens in 5 years.
Not trying to stir things, just having some fun /w3tcompact/icons/smile.gif!
/ Trailer sway #31
<font color=blue>Shoulda bought the rest of the bed while you were at it........</font color=blue>
Reminds me of the time I'd walked in to pick up some coffee while the truck filled up with gas. As I was talking to the ladies I referred to the truck as a she.
One of the ladies, obviously a character, asked just how I knew the truck was a she.
I looked out at the the truck, turned to the ladies, and asked if they'd ever seen a butt that big on a boy.
/ Trailer sway #32
<font color=blue>Saaaaay What? That's as long as they come! Full 8'</font color=blue>
No, mine's thirteen full feet long! One time getting some sand and gravel in Arizona when the nice young lady behind the counter told me politely that it was eleven dollars a pickup load. I told her that was fine but she might want to see my pickup from Texas before she committed to that price./w3tcompact/icons/laugh.gif
/ Trailer sway #33
Derek,
Kinda hard to buy a Chevy (for me) with my little Bro being Sales Director for one of the largest Ford dealerships.
BTW we have a Lutz's Towing around here too.
Oh..... and 2 of the Lutz's also work at that dealership, so guess what they drive. /w3tcompact/icons/laugh.gif
/ Trailer sway #34
I have a Ford F150 Extended Cab and frequently tow my Porsche to the track (3400 lb of car) on an 18' automotive trailer. I've found that weight distribution is hyper-critical and the load on the hitch has to be more than on the tail or else your handling of the rig is all shot.
My first tow with the Porsche on the back was a disaster, at 65 mph the rig was swaying all over the place. Funny, it never did that with the BMW back there and both cars were on the same spot on the trailer and weighed the same!
After thinking about it a bit I realized the problem was the Porsche had a 35/65 weight bias with the rear engine, vs. the 50/50 of the BMW. After that, the Porsche was backed onto the trailer and all was fine. Just getting that weight to the front solved the bulk of the problems.
One other item that really helped a lot was the addition of supplemental Air Bags to the F150. I installed these in an evening with the optional onboard air compressor and they work perfect for hauling the trailer as well as just using the pickup itself with a load of topsoil in the back. Highly recommended. When the back of the truck is dragging or weighed down, just hit the air button until it levels off. Here's where I bought mine and more info on it:
http://www.centuryperformance.com/airlift/index.htm
-Duane C
/ Trailer sway #35
Its hard to follow this thread! goes from trailers-truck/brands-back to trailers again. Question for you that started this thread. If I am reading this right, you are loading the tractor in the forward position...correct? and the weight is to much on the reaqr of the trailer, thus making you fishtail. Try backing the tractor and impl. onto the trailer? Also, if i read it correxctly, something about sag?(i think) when I load my trailer...17 ft flatbed, I made a "chunk" to go under the backend of the trailer. Just think enough to go under the trailer with ALL the weight on it you are going to carry. Put it under the backend before you load. The trailer will "bottom out" against this "chunk" and take the stress off your hitch when loading. When you are ties down, thro it in the back of the truck so you got it to unload. Dont do the same mistake i did at 1st tho. Made the 1st chunk for the space unloaded. When it was loaded, couldnt get it out!
/ Trailer sway #36
I use a concrete block with a 2x6 on top. Be sure and check to see that your hitch is locked. I had a guy hook up my trailer one day for me. This guy didn't lock the hitch and I didn't double check. I found out about it when I went to load my 8N. I ran the tractor up the ramps and the tongue flew up and smashed the tailgate on my 3 month old $30,000 Dodge Ram. I was not a happy person. I had ran the truck and trailer all the way into the lot up to the fence so here I am, tractor on the end of the trailer, tongue in the air, no way to pull the truck out of the way to let the tongue drop without hitting the tailgate again. It took awhile to cool off enough to think and then I chained the front of the tractor to the front of the trailer and drug it back far enough to miss the truck. Moral of the story, always block the back of the trailer and always double check your hitch connection.
/ Trailer sway #37
I guess that's another reason to get an electric hydraulic tilt bed trailer. I can actually load or unload mine safely whether it's attached to a hitch or not /w3tcompact/icons/smile.gif This is, of course, assuming a good, level base for the jack stand and the wheel chocks I always use being in place.
I just love that trailer. /w3tcompact/icons/love.gif It pulls straight and true loaded or empty. It even has a platform on the back that allows me to load the front wheels of a car or truck and pull it behind like you would on a car dolly. /w3tcompact/icons/cool.gif Even with that and the two pivot points, there's no sway. /w3tcompact/icons/smile.gif
It doesn't matter whether it's behind my 4x4 Chevy Tahoe or I'm using the receiver hitch on the back of my 98 Peterbilt with Cat power (for you Ford guys who obviously don't really know, THAT, gentlemen, is a truck). /w3tcompact/icons/grin.gif
/ Trailer sway #38
I'm sure family get togethers would be interesting if you had a Chevy/w3tcompact/icons/laugh.gif.
Lutz is actaully my father's first, the last name is to long and harder to remember. Its a family business. We service, repiar and diagnose cars and light trucks; due towing and recovery (near a ski area); Plow and sand 110 drive ways. Enough to keep us busy.
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=photos&Number=101713&page=&view=&sb=&o=&vc=1>Link</A> to few recovery pictures, there are some at the end of the tread too.
We a customer come in with a picture of a Lutz's towing from Ohio, I think.
/ Trailer sway #39
Same thing happened to me the first time I let my son hook up the trailer to my Expedition. I always warn about not denting the license plate (pet peeve of mine). Hitch jumped past plate from receiver hitch straight into the middle of the tailgate. Safety chains kept the damage from being worse.
Peterbilt 377 Semi-Truck (A63689)
Peterbilt 377...
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
211299 (A62131)
211299 (A62131)
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63689)
PENDING SELLER...
429872 (A61166)
429872 (A61166)
