Trailer plug receptacle recommendation
/ Trailer plug receptacle recommendation
Thanks guys.
I'll pick up some dielectric grease and let it works its magic.
Blane
/ Trailer plug receptacle recommendation #22
Thanks guys.
Blane
It prevents future issues generally, not fix existing ones. You'll need to clean any existing corrosion off or replace connectors first.
/ Trailer plug receptacle recommendation #24
Also check for corrosion INSIDE the plug. I had a plug which worked most of the time. On disassembly it was corroded inside and must have made contact occasionally.
/ Trailer plug receptacle recommendation #25
For cleaning inside the plugs I've used dental picks to scrape, folded emory cloth to scrub, and rifle cleaning brushes especially for round terminals.
/ Trailer plug receptacle recommendation #26
All the posters have great advice. Over the decades, I have dismantled perfectly working plugs and recepticles and done an **** maintenance on them BEFORE they give me a problem. I have encountered frays and rogue pieces of wire, along with corrosion in its' infancy. Just figure it is a given that your stuff is gonna go haywire sometime. A lot has to do with your locale., In Western Oregon, rust never sleeps, although it shacks up with corrosion.
/ Trailer plug receptacle recommendation #27
Many plugs corrode internally - under the plastic / rubber, you won't see it until you cut it open - with all the towing you do I would do a couple of things, I'd get a trailer wire maintenance kit - it comes with pin cleaners, wire brush, files, grease, cotton swabs and instructions, a few companies make them - some better quality than others but at least you'll have the proper tools to do the job, each piece can be replaced with better quality if / when needed - I'd also replace the harness with an all-weather one, the all weather are blue, not only are they sealed better they don't stiffen in cold weather a major plus for snow users!! You also want to make sure the trailer battery is in good shape - the battery can cause issues with the system, even when you thing the truck power is taking over. A simple trailer plug tester will let you know if your getting the proper power to the trailer another nice item to have - sounds like a lot but like worth not having to test the pucker power....
Freightliner Tender Truck - Adams Tender (A61307)
Freightliner...
Iranch IRGC40 (A60463)
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
Informational Lot - Financing (A61307)
Informational Lot...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2013 John Deere 333E (A60462)
2013 John Deere...
