trailer deck
/ trailer deck #1
barticus73
Clarksburg, Pa(Between Indiana and Saltsburg Pa)
Cub Cadet 7272,Farmall 544
Hello,
I have an 18' 12000lb. rated flatbed trailer that I use to tow my trailer around. The wood deck needs replaced and I was wondering what you guys recommend as far as type of wood to use, treated, etc....
The current deck is 2 x 12's untreated and painted.
Jerry
/ trailer deck #2
treated 2x12's painted with used motor oil works well
/ trailer deck #3
</font><font color="blue" class="small">( flatbed trailer that I use to tow my trailer around. )</font>
You tow a trailer to haul your trailer? /forums/images/graemlins/confused.gif
But seriously, I recomend PT 2x6's instead of 2x12's, there will be less cupping and splitting with the 2x6's
/ trailer deck #4
Was it on this site that someone was saying of you put treated lumber down on steel it will cause corosion?
My trailer has survived nearly 10 years with an untreated wood deck. When I rebuild it, I think that's what I'll use.
/ trailer deck #5
This trailer had treated 2x10's when I bought it. They were not the best of boards.... I have a friend who runs a small sawmill. He sawed out some 2"X 8" White oak for me. It was dried for about a year before cutting, and a good 6 months after sawing. It gets soaked with 3 parts used motor oil/1 part diesel fuel at 2 month intervals. The rough sawn lumber gives superb traction. White oak is stronger than 40 acres of onions...
/ trailer deck #6
or 10 acres of cabbage on a warm november day, how long is the trailer?
/ trailer deck #7
</font><font color="blue" class="small">( or 10 acres of cabbage on a warm november day, how long is the trailer? )</font>
20' + 5' dovetail. It looks longer than it is for some reason. That's an 8-row cultivator sitting on it. The frame is 20'-6".
/ trailer deck #8
I've heard that hemlock makes for good decks. Anybody know for sure? I've got a manual sawmill and lots of hemlock trees.
/ trailer deck #9
I'm East of Syacuse and it seems that Hemlock gets used for almost everything - framing, siding, hay wagons, etc. I think for heavy equipment trailers though most like stronger hardwood like oak or maple. I sawed up some 16' maple for a guys excavator trailer and he was in heaven.
Saw that Hemlock up though and you will find something for it.
Larry
/ trailer deck #10
I suspect rough sawn hemlock would work just fine for trailer decking. I used 1" for new siding on my cabin and, after a couple of years drying, the stuff is pretty darn hard.
/ trailer deck #11
Go to a local lumber yard that can get rough cut oak boards and have some 2" thick one cut to lenght. They will last forever.
BLANTON 106" PULL TYPE DRAG HARROW (A63290)
BLANTON 106" PULL...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
Great Plains Harrow Rolling Spikes (A63116)
Great Plains...
200 GALLON FRONT MNT POLY TANK & BRACKET (A63745)
200 GALLON FRONT...
