Trailer came off ball?
   / Trailer came off ball? #1
hoseman28
I have a trailer that I just bought and while pulling it with some mulch loaded over the axles and to the rear (which made the tongue light ) the trailer unhooked from the ball hitch.The tongue coupling is an Atwood which takes a 2 in ball.My question is what should I be looking for I have seen the couplers that have a nut on the bottom to adjust the fit of the ball ,but this coupler does not have that.any suggestions? ty Darrin
   / Trailer came off ball? #2
Do you by any chance have a 1 7/8" ball or a 2 5/16" coupling ???? Did you have a locking pin in the coupling? MikeD74T
I have a 2 in ball and the coupler says 2 in .I did have a bolt in lock.
   / Trailer came off ball? #4
Aside from loading it wrong; you must have a worn out coupler if you are certain the ball and coupler are matched.
   / Trailer came off ball? #5
I had a new one uncouple on me and it was because it was not adjusted properly off the shelf. Just a matter of tightening the nut on the coupler to make it clamp the ball.
Steve
   / Trailer came off ball? #6
I have never seen a coupler, that you cant adjust. Sometimes its a nut on the bottom and other times, you turn the locking arm, to tighten the device.
If I had your problem, i would buy a new 2" ball, put it in the coupler and lock it and see if it feels tight. If its loose, try a 2 5/16" ball and seeif it will work. There is a small chance that the coupler is marked wrong.
Always load a trailer, with tongue weight.
Keep us posted
   / Trailer came off ball? #7
Any chance the 5/16 wore off? I know you said it says 2" but maybe it was a 2 5/16" and it has just worn off or is painted over. I would try what the others have said, trying a different 2" ball and a 2 5/16" ball.
Chris
   / Trailer came off ball? #8
If the trailer is new I would take it back . Explain problem and go from there. If bought used, I would replace the hitch with a Bulldog hitch.
Do you have any pics of the Atwwod hitch? Most do have an adjuster nut on the "jaw". Did you have a pin to lock the lever on the top of hitch in place once it was hooked up? I have seen Atwoods pop open if there was no pin locking the lever on top..........not often, but has happened. That pin is often over looked, that why I prefer the Bulldog style. Post what you find.
   / Trailer came off ball? #9
Bet it's 2 5/16ths
   / Trailer came off ball? #10
I;ll go with a coupler that was adjusted too loose or was not locked in place with "thumb lock"
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A52472)
2021 ALLMAND BROS...
2015 International DuraStar 4300 26ft. Box Truck (A51692)
2015 International...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
RoGator RG1100C (A52748)
RoGator RG1100C...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
2004 FORD E350 MECHANICS TRUCK (A52576)
2004 FORD E350...
