Trailer came off ball?
/ Trailer came off ball? #21
I got your toys, 2006 F-350 PSD 4x4, 2004 F-250 PSD 4x4, 1999 F-350 PSD 4x4, and the grocery getter 2007 F-150 4x4. We tow loads every spring and fall with Pintle hitches upto 80,000# using everything from the F-350's to Dump trucks and even Peter Builts. You are a either blind or dumb if you think there is no wear to the drive line of anything if you are towing with a Pintle hitch. There is slop that is not there with a ball hitch or 5th wheel.
Like I said before the Pintle setup has its place but it is what it is.
Chris
/ Trailer came off ball? #22
Have I got it right that you should load your trailer for 10% tongue weight?
That would make my trailer with tractor weight of 8800# give a tongue weight of 880#.
/ Trailer came off ball? #23
"I have never seen a coupler, that you cant adjust."
I have a couple bulldog type that have no adjustment. probably don't need one due to the design.
Couplers have been known to wear out so badly that a ball is not properly secured. Negative tongue weight would certainly be one way of finding that problem. I have never heard or seen a recommendation from any authority to use less than 10% tongue weight.
Pat
/ Trailer came off ball? #24
Chris
Ford = Toy.....:rolleyes: So I am sure you are having drive train trouble
/ Trailer came off ball? #25
I had our 4 ton equipment trailer come unhooked going up a hill empty, I had already towed the trailer 20 miles. I believe I didnt make sure the coupler was locked down properly. Now every time I hook the trailer up before I crank up the jack I start cranking it down and make sure the coupler is properly latched. V
/ Trailer came off ball? #26
Big Horn, Begin reading about "Dodge". Probably won't be around in a few years.
/ Trailer came off ball? #27
Harry, 10-15% is often the recommended tongue weight.
Some references say 5-15%,
I have never seen less than 5% recommended by a credible source.
If your hitch or truck can't handle the tongue weight at 5-15% then maybe you are overloaded and or need weight distributing hitch.
Pat
/ Trailer came off ball? #28
Dodge = Made in Mexico.... But not for long, all the workers are all moving across the border.
