Trailer Came Loose
/ Trailer Came Loose #41
I had a trailer come loose on me. The nut came off the ball. The chains snapped. No damage to the truck. Repaired the trailer, better than new. The stock chains were WAY underrated.
Lessons learned:
1. make sure the chains are up to the rating of the trailer and hitch and properly mounted.
2. regularly check the torque on the trailer ball.
/ Trailer Came Loose #42
I've seen way too many 1/2 tons pulling large enclosed trailers. I seen a 1/2 ton truck hauling a Famall Super M on a snowmobile trailer. The trailer looked like a banana with axles. Seen much more, but it would take too long to list them all.
The only thing that happened to me was, I was towing a small 8x8 tilt trailer, empty, and the tongue broke off the trailer (not my trailer). I had the tongue with hitch and chains still hooked to the truck while the bed and axle took a trip into the ditch. Not only have I alway's hooked up my own trailers, I now only haul my own trailers.
/ Trailer Came Loose #43
A friend of mine lost a trailer the other day. It's a fourteen thousand GVW dump trailer.
Here in north Texas we are in a drought that's reached almost biblical proportions. Our local lake is something like fifteen to eighteen feet low, 85 billion gallons shy of normal elevation. Between the drought and the it's effect on the clay soil our roads in the country are a delight. Every cut ever made whether it's for utilities or drainage is a visit to Disneyland at any speed. Bridges are like rail road approaches. It's a mess.
Typical morning of running late and trying to make sure he had everything on the truck for his job of the day. Evidently he didn't close the coupler. He hit a bridge, felt something different, looked in the mirror, saw more trailer than he should. He hit his brakes easy and started bringing everything to a stop. Then he reached down and manually operated the trailer brakes to keep the trailer off the truck. Safety chains broke and the trailer ended up okay in the middle of a pasture.
The coupler is a two and five sixteenths. The safety chains are the good ones. I know. I made the trailer. I installed the safety chains. The only thing I can figure is he locked down the brakes and they caught a bump. The trailer was loaded btw.
I believe I've had four lost trailer events in forty plus years of towing. That's all that I can remember anyway. Two of those involved a small trailer that I'd made that was enclosed with utility boxes. It was a custom welding rig. I had a pintle hitch on it. Twice at low speed I had it disconnect at the same railroad crossing. Both times it was low speed and somehow it hit just wrong and opened the pintle. It's something I've never see except with that pintle and that trailer under those circumstances.
The first time I assumed I hadn't closed the pintle which caused me to always double check the coupling after that. The second time I knew I had closed it for sure and ever since I use a giant safety pin that you get at welding supply store. My trailer I use all the time is a pintle and to this day I won't move without that safety pin in place.
Both of those times I felt the trailer uncouple and caught it with the truck and chains, no harm, no foul.
The scariest loose trailer event involved a Bobcat skid steer I'd rented from Nations, their trailer with a Bulldog coupler, heavy heavy evening traffic, and other people loading the trailer and binding it down so I could get the tractor back before closing time.
Three lanes, I was on the inside, forty or forty five mile zone, packed with cars when I felt something wrong in the middle of a curve. A glance in the mirror told me I had more trailer than I should have.
I put on the brakes, very gently, felt the trailer touch the truck, and brought us all to a stop. They'd loaded the tractor where it was just tongue heavy enough to keep the tongue and jack off the concrete. So I popped the binders loose on the tractor backed it up just enough to lift the tongue. Backed the truck under the tongue. Pulled the tractor forward to couple the trailer and add tongue weight. I bound down the tractor and secured the trailer properly. We made it to Nations on time. It took me little longer to do it than to tell it. It was one of those situations where everyone was driving by all irritated but a couple of laborers stopped by to help me line up the couple where I backed the truck up.
Again, no harm, no foul.
The last time involved the two inch insert in the hitch and two and five sixteenths coupler. I was in a hurry and hooked up. Discovered my error when I tried to put the tractor on the trailer. So again, no harm, no foul. I hadn't left my bud's place, his trailer.
/ Trailer Came Loose #44
RobertN said:
I have found that I am much more aware of this these days. after al the discussions here, I am very aware of the requirements for towing too; ie chains, crossing safety chains, gcvr, gcwr ect.
You don't need all this : Just stick this bumper sticker on the back bumper of your truck.
If You Can Read This, I've Lost My Trailer.
/ Trailer Came Loose #45
If you are towing with a pintle/lunette, ALWAYS put a pin or clevis through that little hole in the latch. They can open without it, see the post above. They wont open with a clevis in there though. Cheap insurance.
/ Trailer Came Loose #46
I just remembered a trailer mishap from a few years back where I was the victim. We have/had a rather large pile of railroad ties from when they tore up a local line. A lot of them were real old, maybe original ties that were just logs with 2 sides cut flat. Anyway's, among the pile I found a real nice one that had a lot of character. It had a nice sweeping curve in both directions, kind of like a straightend out "s". I decided to use it as the post for my mail box. Mind you, this is a BIG tie, not a little 8x8, it was wide on the uncut sides.
So, one day the guy who works at the auto salvage place down the road comes to the house and tells me he hit my mail box. I didn't hear anything, so I figured he just side swiped the box itself. I get down to the road, and EVERYTHING is gone. The post, which was very solid, literally exploded on impact. He had tried to tow a trailer with a 2 5/16 coupler, on a hitch with a 2 inch ball. He hit the dip in the road from some recent culvert work, and the trailer came unhitched. No safety chains, the trailer came off, rode down the side of the ditch, hit the road approach right after hitting my mail box, and ended up in the middle of a corn field. He was really, really lucky the trailer didn't go down the middle of the street and go head on with a car. BTW, the trailer was empty.
/ Trailer Came Loose #47
My story: In-laws bought a generator and had it delivered. Delivery guy dropped it right in the middle of their driveway blocking almost any entry/exit. I came home, hooked up the carryall to my little tractor and hooked up the trailer to the truck. Got the tractor slightly up the ramp when the tongue lifted off the ball. It was very cold/rainy and ice had built up in the coupler so that when it bottomed out and I latched it it bottomed out on ice. Now there I am, tractor half on and half off the trailer, front of the trailer hovering over the ball pulling on the chains. If I move the tractor at all the tongue goes into the back of the yukon. I get off the tractor leaving it running but in neutral and the parking brake locked. Fortunately I was in 4wd, so the rear tires being locked held the trailer through the front tires on the trailer to keep it from rolling forward. I blocked the trailer tires and pulled the truck forward slightly to pull the tongue down and get a bit of room between the two. Then I pulled the tractor forward oh so slightly, an inch at a time, each time getting off and checking to see what difference it made at the tongue. Finally got to the point that I could stand on the tongue and my weight caused it to come down onto the ball. After I got the ice cleaned out and the thing firmly locked on, I drove the tractor the rest of the way on. Funny side note to that, the generator was large and the tractor small, so that when I picked up the genny the front tires came off the ground so I drove it into their garage in 2nd gear at just above idle steering with the cutting brakes.
All that aside, I'm pretty **** about the trailer. I always stop at the end of my driveway (couple hundred feet of gravel with lots of bumps) and do a complete trailer walkaround check, making sure that the lugnuts are present and tight, tires are properly inflated, gate's latched, all lights work, coupler's latched, chains are on and crossed, hitch pin is in and secured, etc... before I take it on the road.
/ Trailer Came Loose #48
I am very dilligent when it comes to keeping the trailer and tow vehicle tip-top. Starting with the correct air pressure in ALL tires and everything hooked up properly. I periodically check the hitch and ball fasteners and keep the trailer axles greased. Nothing worse than sitting on the side of the road with a flat due to under inflation. Especially when it's on the drivers side and you have your rear end sticking out on the road trying to change it... in the rain even! Another area of neglect is the trailer brakes. They must be adjusted periodically and checked for wear at the appropriate intervals. What a big difference it makes when the brakes and the controller are all properly set. A buddy of mine bought a new trailer in Florida and pulled it all the way up here empty. Evertime he hit the brakes the tires locked up and he finally called the guy from somewhere in NC and he explained to him to back the brake controller off a bit. He knew nothing about the set-up he had just had installed and the trlr company assumed he knew what he was doing. Couldn't imagine having the death of anyone on my conscious due to my laziness or neglect. Takes a few minutes extra to get it right, take the time and do it right. :)
John
/ Trailer Came Loose #49
the foreman at the shop I worked in had a close call he went over the rail road tracks about 1/4 mile from his home and the trailer came off the 2'' ball (trailer had a 2-5/16'' hitch) the safety chains held but suspended the rear of his Ford explorer , he was unable to move forwards or backwards in addition to realizing if the train was on schedule it would be there in about 5 minutes, unable to move or unhook the trailer plus being able to see the train coming about a mile away he overcame his panic attack , put the explorer in 4wd and smoked/ruined a set of tires, was able to get the trailer and truck off the tracks, that weekend he cut-off and replaced all the trailer hitches with the same sized (5 different trailers) hitch
1994 DAKOTA MANUFACTURING CO. / TRAIL-EZE LANDALL TRAILER (A60736)
1994 DAKOTA...
2019 Chevrolet Tahoe SUV (A61569)
2019 Chevrolet...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
SANY SY35U EXCAVATOR (A59823)
SANY SY35U...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
48x4 Mini Skid Trencher (A61307)
48x4 Mini Skid...
