Trailer brakes
/ Trailer brakes #11
Ma bells phone lines are static and dont drive all over hauling tractors.
A soldered connection with good strain relief, and a non corroding dielectric grease would be a pretty good connection.
Look where you see wire nuts.. All on non moving static installs. Open your truck hood, no wire nuts. All molded connectors.
/ Trailer brakes
Lots of good info, thanks.
Guess I should've known I was opening a can of worms.
I'll go with whatever I come up with tomorrow. I know where soldering iron is, not so sure about crimp connectors I've misplaced them. Also need to find heat shrink.
/ Trailer brakes #13
Make sure you use adhesive heat shrink. Otherwise, moisture will enter.
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
Chemical Containers Tank (A57148)
Chemical...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
Dodge Charger (A56859)
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
