2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,610
Middle TN had mid 80 temps a few days ago. Neighbor ran into rattlesnake working the fence line yesterday.
JD's modern ones like on the 4 series seem pretty easy to get on/off.A 4 series John Deere would be a nice tractor. I wouldn't rule out a 3 series either if you find a good deal.
I always struggle with the backhoe question. There a those who say they would never be without one. There are those who who say they seldom get used and/or are a pain to mount/dismount/store. For what they cost, I might go without on my CUT, and buy an old school industrial tractor/backhoe, or a cheap mini ex. YMMV
Not something I'd like to do weekly.JD's modern ones like on the 4 series seem pretty easy to get on/off.
Sure like the Kubota TLBs for my mostly wooded hillside property. 4-post ROPS. Seat swivels so can reach backhoe controls to swing when operating forwards for balance. Heavier built than ag tractors. Great operator deck. Easy 3pt to backhoe change.JD's modern ones like on the 4 series seem pretty easy to get on/off.
How does one plow snow with a excavator?And here's something else to think about. You have an ATV and use that a lot for a variety of tasks. Consider NOT buying a tractor, and instead get a mini excavator. Not one of the tiny piece of $hit things, but a 4-5 ton kubota or other quality brand. Dealing with that downed log in your picture would take literally seconds. You can dig, grade, and ditch trails, install culverts, reach up and grab hanging limbs, pull out or knock over trees that are in the way or growing into your trails. And an excavator works sooooo much better than a tractor mounted backhoe. For all my property maintenance, including miles of trail maintenance, I use an excavator for 5-10hrs for every hr that I use my tractor. The only way I use my tractor for trail maintenance is with the rear rotary mower to keep grasses cut. And you could potentially do that will a pull-behind mower and the ATV.
Only you can figure out what the right answer is for your needs, but give some thought to the above. The only down side to an excavator is that you need to track it everywhere, and the tracks chew up the ground more than a wheeled tractor, but that's not the end of the world unless you are on a finished lawn. And with some practice, you can do a lot of maneuvering with minimal ground damage.
On dirtbike trails we liked to leave fallen trees like that in place. We’d cut a section out if diagonally across a trail on a hillside (a bit too much of a challenge for some). We figured something straight across a flat trail was a welcome challenge to ride over. Also it kept ATVs and SxSs off our trails.Seen on the trails today. Hope to clear it tomorrow. View attachment 3519445
These are hike, mountain bike or snowshoe trails.On dirtbike trails we liked to leave fallen trees like that in place. We’d cut a section out if diagonally across a trail on a hillside (a bit too much of a challenge for some). We figured something straight across a flat trail was a welcome challenge to ride over. Also it kept ATVs and SxSs off our trails.
My CS2511T weighs about 8.5 pounds with some fuel, oil, 14" bar and chain. The dry weight specs of the T and TN are the same. I can't saw without fuel, oil, bar and chain. ;-) Nice light saw.CS2511TN
