Tractors and Small Properties
/ Tractors and Small Properties
Why do you want the trees down? Just curious.
My wife and I like to have a vegetable garden, and we need a place with some sun. There are so many giant oak trees it shades out quite a bit of the yard.
/ Tractors and Small Properties #42
MossRoad, that's definitely an interesting machine you got there. Is it 4wd?
TheYard, I see the debate you're having with yourself here, so I'm just gonna flat out tell it to you like this: get yourself a scut with a [quick attach] loader and a belly mower, you won't regret it. You could do nearly anything with that setup, including adding a grapple, pallet forks, snow blade or blower, stump bucket, tiller, etc.
Getting a tractor with a backhoe as well makes it that much better. However, unless you see yourself digging a bunch around your property, you could get by w/o it, honestly. For shallow digging, a stump bucket will dig out a hole deep enough for planting a tree or whatever.
/ Tractors and Small Properties #43
A subcompact tractor, often referred to as a SCUT here, (Sub Compact Utility Tractor) is great for less than three acres.
They are limited in capability but ample, ample for an acre.
Great mowers. With optional FEL, serve as powered wheelbarrows and can push snow effectively, or operate a rear snowblower with the tractor moving in reverse.
Will operate a 48" Rotary Cutter/Bush Hog.
New, with an FEL and one or two implements figure $20,000 - $22,000
Great fun, within SCUT limitations.
LINKS: https://www.kubotausa.com/docs/default-source/brochure-sheets/new_bx80.pdf?sfvrsn=233d3332_2
T-B-N ARCHIVE: tractor for one 1 acre site: tractorbynet.com - Google Search
I use my SCUT to care for my 18 acres with not a single issue. SO saying that it is only good for three acres depends on what you want to do. If OP were going to start wanting to clear those big trees no way is a SCUT going to work. He would need something a lot bigger.
So any statement that you need x size tractor for y acres is really just a vague guideline.
I have flat ground being used as horse pasture. So my HP needs are a lot less than 18 hilly acres trying to be cleared of trees.
/ Tractors and Small Properties #44
That makes sense. The house my dad built and that I grew up in had 65 large oaks on about an acre and a half. No veggies for us! (we did have lots of moss, however). :laughing:
/ Tractors and Small Properties #45
Yep. One hydraulic motor at each wheel. Articulated and oscillates between sections. Quick and nimble. It has a quick attach on the FEL so I don't have to get off the seat to change implements, unless it's powered, then I have to disconnect a couple hydraulic hoses. Takes about 15 seconds to change an implement. I like it. :thumbsup:
/ Tractors and Small Properties #46
:thumbsup:
It all depends on what tasks you're trying to accomplish. ;)
/ Tractors and Small Properties #47
I have a house on a 1.1 acre lot in eastern Massachusetts that's mostly wooded - maybe about 1/4 acre is grass and the rest is either driveway (almost 400ft), or forest (60' tall monster leaf producing oaks with nasty continually tick infested underbrush).
I've been tackling it with a 22" walk behind mower, 18" chainsaw, weed whacker/brush cutter, 32" walk behind snowthrower, and basically blowing leaves into the nearest spot into the woods, and creating brush piles when I have to take down a tree (often right next to where the tree went down). As I approach 60, I'm thinking that I need a plan to maintain this place for the next 15 years, and depending on my back might be a bad idea.
Would one of these subcompact tractors be a good fit for a property like this? Or would be over-kill? Some of me feels like this is a mid-life crisis purchase, so any advice would be greatly appreciated.
I don't know what climate you are in but with you situation I would seriously look at a cab model with a finish mower.
https://www.kubotausa.com/products/tractors/compact/b50
With you pine trees you might at some point be needing to lift logs and the cab will keep you warm in the winter and the dust out of your face during mowing.
I'm not sure the back hoe would be worth adding on ($8k option) because you can rent what you need when you need it. I have 45 acres with 40 acres of heavy woods and in 3 years I could have used a backhoe twice.
/ Tractors and Small Properties #48
Some years ago I had to clear some towering (30-40') oaks for a new leeching field. At the time oak lumber was $6 per board ft. (1" x 1" x 12"); I had $$ in my eyes until a friend said "there isn't an oak tree in New England that doesn't have ants." Sure enough, they all had ants, and I ended up burning them for firewood.
Not knowing your specific lot and trees, I have to generalize. With the exception of a few straight, former "field" trees all the oaks on my land and most of the oaks I see in the woods and formerly wooded sub-divsions in MA are curved and appear distressed if not unhealthy. You might want to consult with an arborist (horticulturist) as to which (if any) of your trees should be removed first and site your garden accordingly. For removal, a tree service (whack 'em & hack 'em) would probably be cheaper than an arborist and could be contracted for stump removal. It takes me over a day to limb, buck, chip the slash, and haul the logs to the woodpile (leaving the stump to rot) when I have a 16" oak blow down. When I had tree service remove a 24" cherry between my house and the power lines that I did not have the courage to tackle myself, they were on site for 2 hours with a crane, chipper, skid steer and two trucks plus 6 men and a detail cop.
From my perspective with 1.1 acres you would be better (and more quickly) served by hiring out the large, capital intensive equipment tasks and leaving yourself with a SCUT or even 2-wheeled tractor for yard work.
/ Tractors and Small Properties #49
I am in the buy a BX with a loader camp.
Initially I had a bit over three acres, and bought a BX with MMM and a B2910 with Loader and backhoe. Never regretted either purchase.
My Tractors are both over 16 years old now. Both work as new. Average hours are about 1500 on each.
The BX would be the last tractor you ever buy I would suspect, unless you get tractoritis, and find you want more tractors, or bigger ones! :laughing:
The loader is invaluable. Don't forget to buy one if you buy a SCUT.
/ Tractors and Small Properties #50
I live in central MA and I just bought a BX2380 it was delivered the 29th I only have about 1/3rd an acre at this house and in the works on a few acres soon. I can tell you with the snow that we had the last few days that tractor was well worth it! I have several projects I needed the tractor for and can tell you it will suit your needs. They are very maneuverable and can come in handy for odd things. We also have a Mahindra emax25 and a JD4044r but they are at larger properties. I don’t find it to be a midlife crisis at all I’m in my 20s and just wanted a tractors for projects. If you do go with a BX and plan to go in the woods go with the R4 ties and a underbody protection kit because they do sit a little low. All of our tractors have the R4 tires and they haven’t hurt the lawn unless it’s muddy out and for plowing purposes I haven’t gotten stuck at all. Good luck feel free to PM me if you have any questions about dealers I paid 15604.00 out the door with tax
Your generalizations are pretty spot on. Two of the trees I need to take out are completely dead - quite sure it's ants, and in the past, at least 50% of what's been cut has had ants right up the middle. I'm definitely under no illusion that there's any kind of $ in those trees.
I took out a couple of large oaks myself during the summer. Took me two weekends (but that also included the bar seizing up on the chainsaw, and cutting into a nail in one of them - both of which required trips out to fix).
Of all the work around here that should be done - this is the job I'd like to have someone else do, but ugh the cost is something else for so many trees.
/ Tractors and Small Properties #52
I checked out your website and saw a couple vids of the power tracs. Yeh, that's a really interesting tractor, I gotta say. That oscillation thing is the cat's meow, I could see that being really handy in my crazy yard. Is the articulation easy to get used to, with all controls articulating/oscillating as well? What's the pricing on these, anyways?
/ Tractors and Small Properties #53
We are straying from your original topic, but you should be able to get some economy of scale. If a tree guy can do x trees in a day, even multiples of x, that is, his crew spends an entire day on site, should offer some savings. Use your neighbors' input and your gut feelings when selecting the contractor. I accepted a bid for some bucket work from the tree service I had used for the cherry and who had done work for two of my neighbors. When he was slow to come out I approached an "arborist" who was working at another neighbor's house. His bid for the same scope of work was over 4X the tree service's bid with a 33% discount (to 2.8X the tree service) for immediate acceptance (red flag?!). The tree service did send a man and bucket truck, and although I characterized tree services as "hack and whack", his man did a better job (pruning right at the branch collar, etc.) than the arborist's crew.
/ Tractors and Small Properties #54
I'm not sure what you mean by the controls articulating/oscillating.... maybe this.... the seat is attached to the front section of the machine, not the back section. The seat never changes orientation to the controls. It articulates under the seat.
It's very easy to operate. You can view pricing at Power Trac's website, as their price list is posted for all of their models and attachments. No dealers. Factory direct only.
Power Trac
/ Tractors and Small Properties #55
...the seat is attached to the front section of the machine, not the back section. The seat never changes orientation to the controls. It articulates under the seat.
Mossroad, yeh I thought it was segmented between the seat and controls. Nifty design.
/ Tractors and Small Properties #56
And what are you going to do with the trees after they are down? Just something to think about
and have the logs taken away to a mill on the other side of town. A tractor would help get the logs down to the street where a truck could pick them up.
Ain't nobody gonna be a'poppin' no three foot oak trees out of the ground. That'll take some serious digging. If the timber isn't board worthy, use it or sell it for firewood.
Yeah - after watching mini excavators on youtube struggle with smaller stumps, it's become really clear that this lot clearing is not something I would accomplish with a SCUT, or likely even something like a mini excavator that I could rent. The original site work was done with what appeared to me to be a giant excavator - it was able to pop out stumps that size in about 10 minutes.
I think for the next step in all this is to let the professionals come in and do all the heavy cutting, lifting and digging, and I'll handle landscape/hardscape installation and maintenance. That probably means something closer to a lawn tractor than a scut.
/ Tractors and Small Properties #58
I have a 1994 Steiner 420 SubCompact with a loader (400lbs max) and it's good for my 4 acres here in Pa. I use the bucket as a big wheelbarrow and in the winter I use a rotating brush to clear the snow. I do not use any salt with that combination and have the clearest driveway by 10am just due to the driveway facing southward mostly. Mine is around 400ft and the Steiner makes all the difference for keeping it clear. In the summer I use a Simplicity 61" ZTR with full suspension to cut the grass. The Steiner could do it too as I have a 48" deck for it too but have only used it as a backup in case something else breaks down (mostly hasn't happened). The Steiner cost me around 8,000 with implements about 15 years ago. The Onan engine is great and I've only had to get it worked on a couple of times for hydraulic leaks and hose replacements. It is a offsetting AWD system and WON'T tear up the turf due to it. And the big Balloon tires don't tread on the fine grass turf yard that we keep nice here. It's been a great tractor and well worth the money I spent on it. I've done quite a bit with it. I have the full loader, brush, grass deck 48" and a leaf blower for it. I sold my grading blade because i didn't need it. A snowblower would be nice but not really needed in our area of Western Pa.
Steve
I wonder why nobody builds 4wd tractor loaders in the size of a garden tractor. Like the old case 400's, that size. If they had something like that, I'd choose that over my gc1710, even if it didn't come with a hoe.
I'm on 2.6 acres, some hilly, floodways/soft ground to deal with, lots of ruts here and there. I was managing most of that with a craftsman gt with locking diff. The massey tractor purchase was mainly for the loader and 4wd.
/ Tractors and Small Properties #59
Steve
I looked this up just now. Those are pretty cool. Is yours an actual loader or a front scoop? Looks like the new ones only come with a scoop.
/ Tractors and Small Properties #60
Mine is the full loader. It's big and heavy. But it can dig and grade (btdt). It's still a subcompact size machine though. Not for digging out stumps. Shrubs btdt though. I've been hired out one time. A guy saw me doing some work for the lady across the street and asked if I wanted to make 100bucks grading and moving some dirt from a area for a shed. Sure thing I said ! About an hour later he had what he wanted leveled up.
Steve
iDrive TDS-2010H...
2022 Blue Diamond Brush Cutter (A64126)
2022 Blue Diamond...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
2009 International 4300 Bucket Truck 55' (A62613)
2009 International...
KUBOTA SVL95-2S (INOPERABLE) (A65643)
KUBOTA SVL95-2S...
New/Unused CFG Industrial H12R Mini Excavator (A65579)
New/Unused CFG...
