Tractor tires, sometimes to soon
/ Tractor tires, sometimes to soon #1
Oldpath05
Super Member
none
After 200 hrs. of hard use, my Galaxy front tires were all chewed up and the tread that was left wasn't much, so I decided to replace them with 7-16 Crop Max R-1 Ag Lug from m.e.Miller Tire. These tire's seem to have more tread shape which I like, most Ag tires I see are still using the 50 year old outdated straight bar tread design, it's beyond time to start putting some more angle on the dangle tread pattern.
/ Tractor tires, sometimes to soon #2
Or just run R4s. My tires have 750 hours on them a lot of it on asphalt and they look pretty good.
/ Tractor tires, sometimes to soon #3
He probably wants traction.
/ Tractor tires, sometimes to soon #4
I'm betting his primary use wasn't on dirt or they wouldn't look like that after 200 hours. R4s will out pull r1s on a hard surface.
/ Tractor tires, sometimes to soon #5
The OP's "soil" conditions must be very similar to mine. Lots & lots of very sharp basaltic lava rock. I have to be very careful that I don't spin a tire or the rocks will surely slice into the traction bars. As it is, my tires at 200 hours have slices in many of the bars. I will have to replace my tires, like the OP, due to slicing and not normal wear. I've found that asphalt will grind on the tires and does not cause slicing.
Correct, lot of sharp rocks, everywhere I go, rocks, some not so sharp but still they raise havoc with the front tires. If I'm not on rocks dirt and ledge, I'm stuck in a swamp.
Digging up stumps and big rocks don't help tires any, but then again the tread om my rear tires are like brand new with same hrs., just a few side wall slices. The rears tires are QH brand, what ever that is. I'm hoping these new Crop Max tire will last longer now that I have most of rough tough digging done, I do like the tread design on-em tho.
Slight issue with that, have to change rims to. When I bought the tractor, I hem-and hawed about which tire to go with, took me half hour to say ok I'll go with the AGs
/ Tractor tires, sometimes to soon #8
You would also have to maintain the same OD as before, since you have mfwd
/ Tractor tires, sometimes to soon #9
Altho the new tires are nice, I am concerned that you have gone to a variant that offers even less tread rubber than an ordinary Ag tread. By intuition this would tend to worsen the original wear/damage issue.​
When it come to R1 AG tractor tires, there just isn't enough tread design to pick from, just straight bars. I dont remember seeing a tread bar count on AG tires, that would an important decision maker on buying tires.
I'll have to count mine and see how many tread bars I lost compared to the the front Galaxy tire's I had, then divide 10 multiply by 7 and see if I gained anymore traction........
/ Tractor tires, sometimes to soon #11
Aren't those new tires what is called "rice tires"? :confused:
They will have LOTS of traction in your swamp!! :thumbsup:
The Crop Max spec. didn't say anything about the rice field, but I think your right, hope they do good in snow.
Don't know what is but when/after I build or buy something, someone always brings up a point that never would of dawned on me. Now I have a bad feeling about these 7-16 tires, so I counted the tread bars on them. I have 13 pointing in and 13 pointing out, 13 has always been my unlucky number. The Galaxy's I replaced had 22 inner's and outer's tread bars, I'll go get my calculator and try to figure out how many tread bars I lost, then see if I can estimate if I can get atleast 200 hrs. out of them. Lessons Learned, count the tread bars before buying.
/ Tractor tires, sometimes to soon #13
I don't think the traction difference would be very big but if you wore out the original R1 tires in 200 hours, you could likely wear the next set out in 200 hours as well in the same conditions. Tire compound or number of plies may make a difference though.
/ Tractor tires, sometimes to soon #14
How does the amount of rubber in each bar compare? Would running chains reduce wear? I thought rice tires had a very aggressive tread like this.
/ Tractor tires, sometimes to soon #15
Reading this post has my heading swimming. What are the tire basics when looking for a new set of tires pertaining to tread count? I mean is there a basic number of treads to use in general farming? I guess you could call me a weekend harmsteader but I hope to change that in the next year or so. My use of my tractor will increase then. Tries are ok now but will need a set in a few years and so I like learning before I spend my hard earned money.
/ Tractor tires, sometimes to soon #16
Its not quite that bad since each tread bar is longer ... but ... the traction load on each bar will be increased on the lower count, contributing to wear in hi thrust usage.
Also, I think new tires are softer for awhile, and cut easier. The rubber seems to toughen up over about a 2yr period.
/ Tractor tires, sometimes to soon #17
Exactly! Bar separation/count, bar angle, depth, shape, ... bias or radial all have an effect variably suited to conditions. I would sure like to see a good experimental study.
90in. Work Bench (A65640)
90in. Work Bench...
Transfer Pump (Electric) (A64127)
Transfer Pump...
New/Unused AGT Industrial YSRT14 Mini Skid Steer (A65579)
New/Unused AGT...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
TRUCK RAMPS (A64556)
