Quick Hitches Tractor Supply Quick Hitch dimentions
/ Tractor Supply Quick Hitch dimentions #1
liledoun
Northwest Piedmont North Carolina
JD 4300
Does anyone have a speeco-Tractor Supply-Northeren Tool Cat 1 quick hitch and know the exact measured distance between the inside of the lower hooks. Cat 1 is supposed to be ~26" but most of my stuff is more like 27". See the attachment.
My local TS does not have one in stock to "measure".
I'm not worried about the top pin height. Mine varies all over.
Thanks,
Jim
/ Tractor Supply Quick Hitch dimentions #2
You're in luck! I was looking at one a couple weeks ago and measured it. It was a Cat 1 hitch at TSC, just like the one in the picture you attached.
Distance between the inside of the lower hooks is 27 1/16"
Distance to the outside of the lower hooks is 29 5/16"
Distance from horizontal line between the lower hooks to the top hook (in the position it was shipped, which is in the center) is 16 1/4". It could go up or down a couple inches.
Thanks, that is all I needed to know. I got one yesturday from Northern Tool. They priced it at $210 but met the Tractor Supply price of $170 and I used a "Farm Show bag cupon" for $50 off. Total $120 with $1.20 tax for farm equipment in NC.
One set of the bushings came with it but I think I can make more for less than the $19.00 another manufacturer sets costs.
Thanks again,
Jim
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2012 Mini Cooper Coupe (A59231)
2012 Mini Cooper...
2025 GIYI SE61 61in Sweeper Skid Steer Attachment (A59228)
2025 GIYI SE61...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-150...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
