Tractor problem
/ Tractor problem #1
Fergieman
Maccormick cx95
My maccormick cx95 starts and then stops after a couple of seconds. It might take six or seven tries to get it started again after which it runs perfect . Its a 2003 model with a perkins engine. Any help would be appreciated
/ Tractor problem #2
I looked it up, looks like made in UK, Perkins diesel. I would start with basic things...I assume it has glow plugs? If so check them and that circuit. Then have you changed filters? Sounds like glow plug problem or not getting fuel.
/ Tractor problem #3
A diesel in reasonable mechanical condition needs a good battery/starter combination and adequate fuel delivery to start. Does your tractor have both?
/ Tractor problem #4
If it starts & stops several times before it stays running, you have a supply problem.. is it gravity fed or does it have a lift pump?
If it has a lift pump, try to clean it.. a lot of them can come apart & have a filter inside..
Check to see if its actually working.. if not replace it.
2014 Ford Expedition SUV (A64557)
2014 Ford...
MARKER LIGHTS (A64276)
2020 Deere 670GP (A64126)
2020 Deere 670GP...
Kuhn GMD 600 (A64127)
265/75R16 New Tire (A62613)
265/75R16 New Tire...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
