Tractor pictures
/ Tractor pictures #171
Nice to see you're still around Rob. Larry G tells me you've been quite busy.
Hi Matt,
Yes, been very busy.
Lots of work to do around the little ranch this Winter. Plus I took a 2 day a week job down South. Right now I'm in the middle of an engine re-build on my Kama. Did an in-frame re-build only to find I have low oil pressure due to a bad crank journal. Turned around and took it all apart (completely) to switch out the crankshaft too, so I'm doing it all over again! Shees...
Here's the link if you haven't seen the thread yet:
Engine Overhaul Kama 554
/ Tractor pictures #172
Here's my 2320 with it's winter clothes on:p
TIM>
/ Tractor pictures #174
Tim:
Have you ever snagged anything inadvertently with your bucket's snowbar while in reverse?
No it's never given me a problem.It's also the best modification I have done so far,couldn't live without it moving snow.;)
Tim.
/ Tractor pictures #175
I brought the JD 850 with me from Texas when I moved from Tex to Colorado in 2006. Then, bought the TYM T450 in late 06. Love it! Now have over 300 hours, and never a lick of trouble.
/ Tractor pictures #176
t man, that looks like it would be the perfect solution for me, I have about 1500ft of gravel (cr6) drive and road to plow/push with the fel. I am assuming that is what you use it for. If possible any other pic. angles of your fel with that attachment. Great idea. If not what size tubing did you use. And is attached simular to a tooth bar.
/ Tractor pictures #177
Double e
I used 1 1/2" black iron pipe.Here are some better pics of it I posted in another forum.
http://www.tractorbynet.com/forums/attachments/158537-front-end-loader-front-edge-2.html
Also check out this one that GuglioLS made.
http://www.tractorbynet.com/forums/build-yourself/161544-front-end-loader-cutting-edge.html
Hope this helps,any other questions let me know.
Tim
/ Tractor pictures #179
The TYM is nice, love Red, BUT THE BACKGROUND scenery is breathtaking. Where exactly are you? Do you have more pics?
/ Tractor pictures #180
Here are some pictures of my tractors :
The first one is my wife on my Iseki tu220f back filling a water pipe trench with a home made blade.
The next one is my Countax riding mower.
The third one is of my Avto tractor, I bought it as a project it is about 45hp and made in Russia so is solidly built with an aircooled engine.
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
30KW GENERATOR (A58214)
30KW GENERATOR...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62129)
KNOW BEFORE YOU...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2018 Chevrolet Colorado Crew Cab Pickup Truck (A61568)
2018 Chevrolet...
Iranch IRGC40 (A60463)
