tractor over heats
/ tractor over heats #1
deere755
Platinum Member
central Illinois near Lake Shelbyville
Case 2090 Massey Ferguson 4233 John Deere 4700
I have a 755. After using it an hour or so it gets hot if you are pulling it. I don't me over pulling it just normal use like mowing or tilling. The first thing I did was check the coolant and then washed the radiator out real good. I went back out and tried it and the same story after about an hour it started to over heat. The second thing I tried was a thermostat. It still wants to over heat. The only thing I can think of is the radiator needs replaced or a good flushing. Any one have any ideas. I also should mentien you can run it all day with out any problems if you aren't pulling it.
/ tractor over heats #2
A few years ago my JD 850 was doing the same thing. If I worked it very hard (mowing, tilling, Etc.) it would overheat.
Tryed the same things that you have done also. (thermostat, washing out fins).
I took the radiator out and had is flushed/cleaned. No problems since. Cost was around $60.
I took my tractor to my John Deere dealer and it needs a new radiator. They are telling me that they so back ordered that it will be the second week in June before I can get my tractor back. I guess I can get by with out it.
/ tractor over heats #4
Check with a local radiator shop and see if it can be recored.
You may be up and running much quicker and possibly cheaper if they can do it.
Worth a try.
Good luck..
/ tractor over heats #5
Like Vince said, take it to a radiator shop. I would even venture to say that you might save as much as 50% if you take it out and take it there yourself.
2011 Lexus IS250 Sedan (A66738)
2011 Lexus IS250...
2007 KENWORTH W900 (INOPERABLE) (A67714)
2007 KENWORTH W900...
2026 SG45 Hydraulic Stump Grinder Skid Steer Attachment (A66734)
2026 SG45...
AIR HAMMER (A64553)
AIR HAMMER (A64553)
2011 FOREST RIVER T/A CARGO TRAILER (A67714)
2011 FOREST RIVER...
CAT 824C GP Gear (A68134)
CAT 824C GP Gear...
