Tractor Logging
/ Tractor Logging #21
Hi there, it all depends on what you need for a rig. I have a 80hp 4wd Newholland with a loader, grapple bucket and a Farmi JL601 winch. I can cut and skidd out up to 40 trees per day (6 to 8 hrs) by myself with this rig. I have pulled pine trees that go 40" at the stump and close to 80ft in length. I have pulled hard maple trees with all the branches that go 30" at the stump. My rig is well balanced and also has a custom built forestry cab. 11000 lbs. weight. As long as you are properly trained the tractor and winch can make you some big money. You could by a JD540 or 640 skidder for about $20,000-but, if you have a breakdown-good luck! Also to consider is transporting your rig. you could drive up to 10 miles easily with a tractor. You can not do this with a skidder. Also, A tractor can be hauled fairly easy as where a skidder you are going to have to have a big rig haul it for you. We typically cut over 200 face cord of hardwood firewood over a period of 2 months during the winter. We sell most of it along with any hardwood logs we get from it. The 4wd tractor you are speaking of with a Farmi JL501 winch would be a great combination as long as it had a loader and rops. The rest of the time the tractor is used for our farming operations.
/ Tractor Logging
what should I expect to pay for such a set up (80 hp with forestry cab)?
/ Tractor Logging #23
A brand new newholland TD80D 4wd with 820TL loader, custom forestry cab, custom grapple bucket and the Farmi JL601 winch will set you back about $45,500(+-). It has an 80 hp rated engine and has been dyno tested at 66.7 pto. The tractor and loader is about $37,000.
2018 John Deere 5075E (A60462)
2018 John Deere...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
SD Lanch SDLGC80 Electric Golf Cart (A60463)
SD Lanch SDLGC80...
2016 Kubota L3301 (A60462)
2016 Kubota L3301...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
2025 Pabreak 84in. Hydraulic Rotary Tiller Skid Steer Attachment (A61567)
2025 Pabreak 84in...
