Tractor Logging
/ Tractor Logging #21
Hi there, it all depends on what you need for a rig. I have a 80hp 4wd Newholland with a loader, grapple bucket and a Farmi JL601 winch. I can cut and skidd out up to 40 trees per day (6 to 8 hrs) by myself with this rig. I have pulled pine trees that go 40" at the stump and close to 80ft in length. I have pulled hard maple trees with all the branches that go 30" at the stump. My rig is well balanced and also has a custom built forestry cab. 11000 lbs. weight. As long as you are properly trained the tractor and winch can make you some big money. You could by a JD540 or 640 skidder for about $20,000-but, if you have a breakdown-good luck! Also to consider is transporting your rig. you could drive up to 10 miles easily with a tractor. You can not do this with a skidder. Also, A tractor can be hauled fairly easy as where a skidder you are going to have to have a big rig haul it for you. We typically cut over 200 face cord of hardwood firewood over a period of 2 months during the winter. We sell most of it along with any hardwood logs we get from it. The 4wd tractor you are speaking of with a Farmi JL501 winch would be a great combination as long as it had a loader and rops. The rest of the time the tractor is used for our farming operations.
/ Tractor Logging
what should I expect to pay for such a set up (80 hp with forestry cab)?
/ Tractor Logging #23
A brand new newholland TD80D 4wd with 820TL loader, custom forestry cab, custom grapple bucket and the Farmi JL601 winch will set you back about $45,500(+-). It has an 80 hp rated engine and has been dyno tested at 66.7 pto. The tractor and loader is about $37,000.
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
2008 FORD F-150 (A60736)
2008 FORD F-150...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
