Tractor hard to start in cold
   / Tractor hard to start in cold #12
Have you given any thought to the hydraulics? Cold oil is a well known parasitic load on any starter. Are you sure you have a low enough viscosity fluid for cold weather use? Does it have a destroke solenoid valve on the pump and is it working?
This.
But more importantly, what is YOUR version of "cold"? What is the coldest temps (NO "windchill" BS) in ambient air temperature that your tractor will see?
Some folks version of "cold" is almost laughable.
Make sure your engine oil and hydraulic oil are rated for the temps you're actually going to operate your equipment in.
Jim
Thanks for the heads-up on the solenoid. I’ll look at it and see. Makes sense that would cause a problem especially in the cold with sluggish oil.
Slim,
I’m in NH, but southern near coast. Used to get cold here, but lately lowest temps are only around 20-25F. Cold enough to gum-up hydraulics but not terribly cold like MN.
   / Tractor hard to start in cold #14
If it starts easily with present batteries when it is warm look at battery replacement.
   / Tractor hard to start in cold #15
I’ll bet batteries , 10:1 over hydraulic oil, being the winner
   / Tractor hard to start in cold #16
I'd lean towards fluids, between engine oil and hydraulic fluids. Plus batteries loosing cranking ability but fluids can make a considerable differences.
  • Good Post
Reactions: JJT
   / Tractor hard to start in cold #17
Stop guessing. Completely remove all batteries and cables clean up all grounds. May be one or 2 depending how it’s wired. ANY corrosion on any cable have new heavy duty ones made. You can load test batteries or you can just get 2 new heavy duty batteries and know everything is good. Stop being cheap and skimping on the correct diagnosis. The fact you don’t know oil weights in your equipment tells me you’re lacking regular maintenance. I run a fleet of 7 agricultural tractors 50-180 hp. Run JD oil 15w/40 in all weather to below 0 degrees. You stated a block heater. Plan your activities during the cold weather and plug it in for an hour. It will make starting easier and take the stress off the batteries new or old
LHF,
I’m up on maintenance on the six tractors I run in the farm. The 310SE is a newer purchase from someone who had done a recent maintenance and so I didn’t see the need to change fluids right away. Levels are good, but do plan to change oil and filters soon to have a baseline. Thanks for the heads up though.
Until Jim had mentioned the destroking solenoid I was leaning toward battery issue. Still the most likely culprit and will verify when chores slow down. Good to know about that solenoid.
Will do as LHF suggests and do electrical first so we figure out what it is or isn’t one step at a time. Many thanks.
Best regards.
   / Tractor hard to start in cold #19
Dunno, I think on a Deere you must move the steering wheel from side to side while starting. Just a thought
   / Tractor hard to start in cold #20
Hi,
I’ve done research but have not found a solution. 1998 John Deere 310SE backhoe with 4.5l (272ci) diesel engine. When mild temps , starts immediately. When cold, will hardly turn over and sometimes not start. Put battery charger on it and it shows batteries almost fully charged. Three guesses as to what might be going on: bad ground wiring; bad starter motor; or batteries (2). I just can’t think of why it starts like a champ all summer, then barely turns over when cold (below 35f). What would be most likely affected by cold temperatures? Seems batteries to me, but curios if anyone has had and cured this problem. Thanks.
Am not saying my idea will solve it but trying couple might work: 1.) AMSOIL engine lube plus (2.) diesel fuel additive, ie, "Diesel All-In-One".
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
CASE 610 Sprayer System 2000 Gallons (A56436)
CASE 610 Sprayer...
404 (A52706)
404 (A52706)
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
