Tractor hard to start in cold
   / Tractor hard to start in cold #1
Dunno
Ford
Hi,
I’ve done research but have not found a solution. 1998 John Deere 310SE backhoe with 4.5l (272ci) diesel engine. When mild temps , starts immediately. When cold, will hardly turn over and sometimes not start. Put battery charger on it and it shows batteries almost fully charged. Three guesses as to what might be going on: bad ground wiring; bad starter motor; or batteries (2). I just can’t think of why it starts like a champ all summer, then barely turns over when cold (below 35f). What would be most likely affected by cold temperatures? Seems batteries to me, but curios if anyone has had and cured this problem. Thanks.
   / Tractor hard to start in cold #2
Hi,
Cold crankng amps...check rating of battery.
Riptide,
Will do. Machine has two big batteries in it now, but not sure how old they are, or CCA. I’ve had it for two years, and I think PO said it didn’t like to start in cold. I’m thinking it just may be worn out batteries, but any other thoughts welcome.
   / Tractor hard to start in cold #4
My John Deere 2020 diesel is the same way. If the temperature is below about 50 degrees it struggles to start. I installed a coolant heater on it many years ago; I plug it in a half hour before using and then the tractor starts just fine. Something like this only mine is probably 30 years old:
   / Tractor hard to start in cold #5
Regardless of what the charger displays, put the charger on a couple hours prior to starting and see if that "fixes" the difficulty. If it does, new batteries are needed.
If the starting is still sluggish, Freshen ALL the battery connections including the one at the starter. Don't be shy with the wire brush and sand paper. Clean and BRIGHT.
Are you running multi-vis engine oil?
   / Tractor hard to start in cold #6
Have the batteries been load tested ?
Plenty of diesel engines don’t start very easy when cold, my Ford 6610 prefers to have the block heater plugged in for about an hour before starting when it get down near freezing temperatures or below.
Some of the newer diesels I have operated start like it’s 70 degrees when it’s 10 below zero.
   / Tractor hard to start in cold #8
Hi,
Have you given any thought to the hydraulics? Cold oil is a well known parasitic load on any starter. Are you sure you have a low enough viscosity fluid for cold weather use? Does it have a destroke solenoid valve on the pump and is it working?
   / Tractor hard to start in cold #9
Hi,
Your description "will Hardly turn over" is the detail that must be known. Discover why that is.
I will tell you it is most likely NOT the temperature of the engine.
Guys,
Thanks for the replies.
Batteries have not been load tested. I’ll remove them and clean all wiring as suggested. While out I’ll have them load tested.
No glow plugs. Strange. Instead, has an ether-shot system. Ether can sits in holder hear engine; hit a button for the shot while starting. I’m Leary about using ether, but since this is a factory set-up, JD must have thought it ok.
Plug in heater is on machine, but often times the need is unanticipated. Will have to think about use and plug in when needed.
Not sure about engine oil or hydraulic fluid viscosity. Has clear hydraulic fluid when shop R&R’d a leaking swing cylinder. Have heard bad and neutral about clear fluid. Still has leak near swing cylinders, and plan to change fluid to better when I do the work on leak this time.
If it turns out to be the batteries, is it possible to install one to get the job done, or stick with the two? ($$). 4 cylinder diesel shouldn’t take much juice, but if it’s fighting hydraulics on start I can see the need for two.
Many thanks for the tips.
2757 (A55787)
2757 (A55787)
2005 CARMATE 7' X 12' V-NOSE CARGO TRAILER (A52708)
2005 CARMATE 7' X...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
Bobcat T590 (A53317)
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
