Oil & Fuel Tractor Flipped, what do I do?
/ Tractor Flipped, what do I do? #1
Reckless
I have a 7100 Kubota that i had holding down a temp, but the wind was so strong it flipped it on its side. Is there anything I should do before trying to start it again? Oil levels are ok, battery is fine, but just wondering if I have to check something else out?
Any help is appreciated! Don't want to start it and cause more damage for not asking first!
Thanks
/ Tractor Flipped, what do I do? #2
How long was it on it's side before you got it upright again. If not too long, then likely you can just let it set for a few days to let any oil that seeped past the rings to drop back into the oil pan. Try to turn the engine over by hand to see if it is hydro-locked. If it turns a couple revolutions without any problems then likely there is nothing wrong and can be started up without doing anything else.
/ Tractor Flipped, what do I do? #3
I agree with Gary, try and rotate the engine by hand by placing a socket on the crankshaft nut. If the engine will not rotate, remove the flow plugs and spin again by hand. If the engine will spin over manually use the starter then to blow the oil out the glow plug holes.
/ Tractor Flipped, what do I do? #4
I laid a Kubota L3400 on its side and it laid there for several hours before I could get the tools needed to get it back on its tires. I let it sit for 30 minutes to allow the fluids to drain back to where they belong, then fired it up. Never had any trouble with it. I think if yours has sat for days you are fine.
Unfortunately, the tractor was on its side for a few days. With the wind so strong it was the only thing holding down the tempo from blowing across the fields and to houses. Good info about turning manually. Not much oil leaked on the outside so hopefully its still in tact. This tractor has worked hard and has never let me down!
Thanks
/ Tractor Flipped, what do I do? #6
Just teasing, but I was wondering, did you pick your name before, or after this accident ? LOL
How are you planning on getting your tractor upright ?, or have you got it upright already ?
/ Tractor Flipped, what do I do? #7
Just curious, what was it you had it holding down? It seems auto correct burned you twice, first time "temp" and the second time "tempo". Was it a tent? And if so, how darn big was this that it tipped your tractor? :eek:
/ Tractor Flipped, what do I do? #8
I think it says on the box to "never tie your tractor to this tempo".:confused3:
Man, you must have some pretty heavy winds where you live.
/ Tractor Flipped, what do I do? #9
Never hook your tractor to a shooting star!?:confused3:
LOL, I got the nick name Reckless when I was younger as I would usually try anything! As for what it was holding down it was a Tempo (canvas portable garage), which was 16' High, 35' long, and 14' wide. We had a windstorm right after the Buffalo dump of snow that had gust around 50mph/80kmh. with the side being pushed by the wind last minute decision to save it was to use the tractor. Figured with loader down and being fairly heavy it should hold....not. I have the tractor upright and in my garage as a neighbour came over with loader and help push it into my shop. Will be checking how it runs in a couple of days (busy getting sleds ready and doing trails. I live South East of Ottawa, Ontario.
/ Tractor Flipped, what do I do? #11
Where exactly are you ?
I am in Fournier...50 minutes east of Ottawa. :thumbsup:
/ Tractor Flipped, what do I do? #12
I,m just south of Ottawa as well, near Prescott.
You might be working on our trails in District 1. Good luck with your tractor, and thanks for volunteering.
Please let us know what procedure you used to get it running again.
/ Tractor Flipped, what do I do? #13
We all worry about our babies when something bad like this happens, but I'm betting that, after sitting upright for several days, the tractor will fire right up and run fine.
/ Tractor Flipped, what do I do? #14
That tractor should have a decompression lever near the steering wheel end of the engine. It will turn over by hand quite easily with that opened. May even blow any oil out of the cylinders if you try to start it with the decompression lever pulled seeing it opens the valves a bit. Mine works but the cable to the console is frozen but I can still move it at the engine.
2012 Subaru Forester AWD SUV (A64557)
2012 Subaru...
2003 Jeep Liberty 4x4 SUV (A64557)
2003 Jeep Liberty...
2025 48in. Farm Jack (A64553)
2025 48in. Farm...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A64553)
2025 GIYI GY-P45...
SARLO (A64557)
SARLO (A64557)
2019 Freightliner 122SD (A62679)
2019 Freightliner...
