Tractor backhoe - homemade
/ Tractor backhoe - homemade
Thanks. I will slide it with the boom, it will have hydraulic lock with 4 single acting cylinders
Welding slide bars...
/ Tractor backhoe - homemade #1,123
Just stumbled into this thread. Very very valuable stuff here! Must read through all of this. Many thanks to BF!!
/ Tractor backhoe - homemade #1,124
Bfreaky, for your reference: Hitachi puts a lot of info in their brochures, with hydraulic pressure, cylinder bore and stroke, bucket force and stick length. They give a sense of ratio for your design.
I am referencing the Hitachi 3.3 tonne model to build behind my 3011. The 3011 weighs less than 3.3 ton but the center of gravity is further away from the tipping point than with an excavator, so you get more stability in relation to the vehicle weight...
https://www.hitachicm.eu/wp-content/uploads/2019/04/Hitachi_ZX65USB-6_mini-excavator_KS-EN438EU.pdf
Thanks. I've already bought all the cylinders. Size is quite similar; lift, dipper, and 2nd dipper will have 100/50 - stroke 800, bucket cylinder will be 80/50 - stroke 800, swing also 100/50 - stroke 200 mm, and stabilizers 60/40 - 700 mm.
Work finally continues. Had to put it on hold because of unexpected injury... cleaning and grinding 1st boom parts
Boom no 1. assembly. Gotta love those dowels, always perfectly aligned parts and so easy to make..
Now I am, I twisted my ankle badly. It set me back 3 weeks
Yup, breakdance on the workshop floor :)
Worst of all was the fact that I had to stop everything, just had to lie in bed with my leg in the air...I'm totally NOT used to that...the day gets alot longer...
/ Tractor backhoe - homemade #1,134
Hopefully you were able to tie a computer monitor to the ceiling and do some CAD! Glad you're back at it, can't wait to see more progress. I really like the dowels for alignment.
/ Tractor backhoe - homemade #1,135
Do they have day time "drama" series on TV there? We call them "soap operas" because they advertised soaps to the stay at home mothers back in the day.
Easy on the break dancing.
/ Tractor backhoe - homemade #1,136
I know the feeling all too well. I’m about 3 days into 6 weeks. I can’t walk for 6 weeks. I’m not technically banned from doing anything else but I’m too sore now to do anything besides sit on the couch.
/ Tractor backhoe - homemade #1,137
Can you use crutches?
/ Tractor backhoe - homemade #1,138
Yes, but that’s about the equivalent of driving with 3 wheels. I have a desk chair for rolling around the house but there’s stairs to get outside and the shower is upstairs. I can go upstairs pretty decent on crutches but going down I have to sit down and slide down them. And I’m too sore to do much now. I’m hoping to be able to at least put a little time on my equipment in a week or so.
/ Tractor backhoe - homemade #1,139
It looks like you put a thin walled tube in the stick nose, then later put a thick walled bush in, to accept the pin and wear bushings ?
Tube in the nose is 110 x 8 mm. Yes, that's the way I'm gonna do it.
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2019 Autocar Xpeditor Garbage Truck (A62613)
2019 Autocar...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
2001 Mack Grapple Truck (A64127)
2001 Mack Grapple...
2015 Case TR320 (A64126)
2015 Case TR320...
