Tracked Dozer
/ Tracked Dozer #1
fixit10101
Central Wis
Has anyone fabricated a Dozer (like a Struck) from the running gear from a zero-turn mower?
/ Tracked Dozer #2
Not recommended if you are going to use it as a dozer as those motors aren't meant for pushing like a dozer does and WILL blow.
/ Tracked Dozer #3
Too light. I've got all the hydraulics from a skid steer we scraped that would be a good candidate though.
/ Tracked Dozer #5
You would be better off with some low torque hydro motors
/ Tracked Dozer #7
Thats pretty slick
/ Tracked Dozer #8
Check out this link. I used a zero turn pump which connected to hydraulic motors. The motors turn the track.
http://www.tractorbynet.com/forums/build-yourself/157345-mini-dozer-project-near-complete.html
Just read your thread on your dozer build. Good advice and great pictures and letting you know I thank you for the link. Nicely done. Good build, just can't say enough good things about it. :thumbsup: Hope the OP has the time to go take a look at the build. Thanks.
/ Tracked Dozer #9
By the way I'm glad these old threads got resurrected. Sure worth reading.
Bulk Lot - (3) Pallets of Electric Motors & Pump Components - Selling as One Lot (A63689)
Bulk Lot - (3)...
2017 TAKEUCHI TL12R2 SKID STEER (A64279)
2017 TAKEUCHI...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
UNUSED IRMC HIGH END MASSAGE CHAIR (A64281)
UNUSED IRMC HIGH...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
BOBCAT HYD MULCHING HEAD (A64279)
BOBCAT HYD...
