Tracked Dozer
/ Tracked Dozer #1
fixit10101
Central Wis
Has anyone fabricated a Dozer (like a Struck) from the running gear from a zero-turn mower?
/ Tracked Dozer #2
Not recommended if you are going to use it as a dozer as those motors aren't meant for pushing like a dozer does and WILL blow.
/ Tracked Dozer #3
Too light. I've got all the hydraulics from a skid steer we scraped that would be a good candidate though.
/ Tracked Dozer #5
You would be better off with some low torque hydro motors
/ Tracked Dozer #7
Thats pretty slick
/ Tracked Dozer #8
Check out this link. I used a zero turn pump which connected to hydraulic motors. The motors turn the track.
http://www.tractorbynet.com/forums/build-yourself/157345-mini-dozer-project-near-complete.html
Just read your thread on your dozer build. Good advice and great pictures and letting you know I thank you for the link. Nicely done. Good build, just can't say enough good things about it. :thumbsup: Hope the OP has the time to go take a look at the build. Thanks.
/ Tracked Dozer #9
By the way I'm glad these old threads got resurrected. Sure worth reading.
2023 Case TV450B (A62177)
2023 Case TV450B...
1929 PACKARD 4 DOOR SEDAN (A59909)
1929 PACKARD 4...
UNUSED ATS ACE80-80 GALLON ELEC. AIR COMPRESSOR (A62131)
UNUSED ATS...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
17601CFL (A59228)
17601CFL (A59228)
2018 CATERPILLAR 262D SKID STEER (A62129)
2018 CATERPILLAR...
