Tracked Dozer
/ Tracked Dozer #1
fixit10101
Central Wis
Has anyone fabricated a Dozer (like a Struck) from the running gear from a zero-turn mower?
/ Tracked Dozer #2
Not recommended if you are going to use it as a dozer as those motors aren't meant for pushing like a dozer does and WILL blow.
/ Tracked Dozer #3
Too light. I've got all the hydraulics from a skid steer we scraped that would be a good candidate though.
/ Tracked Dozer #5
You would be better off with some low torque hydro motors
/ Tracked Dozer #7
Thats pretty slick
/ Tracked Dozer #8
Check out this link. I used a zero turn pump which connected to hydraulic motors. The motors turn the track.
http://www.tractorbynet.com/forums/build-yourself/157345-mini-dozer-project-near-complete.html
Just read your thread on your dozer build. Good advice and great pictures and letting you know I thank you for the link. Nicely done. Good build, just can't say enough good things about it. :thumbsup: Hope the OP has the time to go take a look at the build. Thanks.
/ Tracked Dozer #9
By the way I'm glad these old threads got resurrected. Sure worth reading.
2019 John Deere 4044M (A62177)
2019 John Deere...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
UNUSED WOLVERINE JMR-22-8.5G SUSPENDED RIPPER (A62131)
UNUSED WOLVERINE...
2018 CATERPILLAR 315FL CR EXCAVATOR (A62129)
2018 CATERPILLAR...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
UNUSED WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A62131)
UNUSED WOLVERINE...
