Towing a BX24
/ Towing a BX24 #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
I'm going to potentially need to transport a BX24 next month, and I don't think that my 95 Dakota is really capable of doing it with its 8000 pound GVW rating. I have access to an 02 Lincoln Navigator, which I believe shares a chassis with an F150. This vehicle has a 9,000 pound GVW rating. Would this vehicle be capable of transporting a BX24 60-70 miles, mostly on an interstate, does anyone think/know? I live close enough to Delaware, which is tax free, so I'm looking into the possibility of making a purchase in that state to save close to $1000 in taxes.
Thanks
/ Towing a BX24 #2
I have no problem towing the BX with my GM Yukon. Ttrailer and BX are under max tow capacity. . The important part is the trailer you will be using. You will need two axle trailer with brakes in PA probably min of 14 ft in length. Four Acre's in DE has them. I have a hyudraulic dump trailer from them and do not haul BX in that as it is to high off ground, but he has beautiful trailers for hauling BX.
/ Towing a BX24 #3
Thanks
It will tow it just fine, in my opinion. It may not pull with comparison to larger trucks, but it will got-it-did.
Use the truck's gearing for hills, be kind to your truck with patience and it will do OK. The BX24 isn't that heavy of a load.
The Nav would indeed pull it with a bit less struggle, saving wear and tear on your Dakota's tranny. There's where I'd opt out for the Nav....
/ Towing a BX24
Thanks for the feedback! If it turns out that the Dakota can tow this thing, I'll be jumping up and down with extreme joy. If I'm about to shell out the money for the tractor, I would definitely not have any interest in having to then buying a 1/2 or 3/4 ton truck in addition! I could swing a trailer if need be, but not a truck too this year.
/ Towing a BX24 #5
This very day a buddy of mine tows an L2800 on a 16' tandem axle with his Dakota and doesn't have any problems. Plenty of hills here too.
I still say use the Nav and save the wear on the Dakota... :D
/ Towing a BX24 #6
I pull around a 16' tandem with a BX with FEL and BH all the time with a 4.0L Explorer. No issues at all. Trailer and BX combination are still under #3500.
/ Towing a BX24 #7
I believe that the 95 Dakota has a 3,500-lb tow rating, and a 350-lb tongue weight rating. If your tandem trailer weighs about a 1,000 lbs or so, you should be able to haul your BX24 legally on your local highways.
/ Towing a BX24
This is especially likely to happen actually, because the Navigator is getting traded in or sold after it serves this purpose if it has to. :)
/ Towing a BX24 #9
Taking your time and having a trailer with electric brakes (along with leaving the appropriate space cushion) will go a long way for an easy tow. You should not have any real issues so long as you should
/ Towing a BX24 #10
I tow a 16 ft tandem trailer with brakes on both axles loaded with a B6200 with loader & backhoe & other attachments with a dodge dakota and have no problems at all. I do lock out the overdrive though most of time as it shifts up & down too much otherwise.
/ Towing a BX24 #11
My father used to tow my B2410 with loaded tires and backhoe all the time with a 16' dual axle trailer (brakes on both) using a Ford Ranger 4.0 liter. He towed it 60 plus miles each way, 55 miles of which was interstate.
/ Towing a BX24 #12
Your Dakota should be fine towing that weight. The BX w/BH and loader weighs in at around 2700. Add trailer weight of around 1500, youre around 4200. Thats not bad for a Dakota. As was mentioned, just use the right trailer for the task (ie. tandem with electric brakes).
I intend on towing my BX23 the same way with my Jeep Cherokee. The tow capacity of my Cherokee is 3500 without load leveling and 5000 with load leveling. I would think you Dakota should have a higher tow rating than my Cherokee does, its heavier, its longer and its wider.
/ Towing a BX24
The feedback here is very encouraging. I love my Dakota and it has served me great towing lighter garden tractors. It sounds as though I'll be able to get by with just buying a better trailer (my 10 foot single axle won't do) as opposed to a trailer AND a new truck! Thanks again everyone.
2005 International 4300 55' Bucket Truck (A62613)
2005 International...
Fencing Wire (A62613)
2016 Deere 310L (A64126)
2016 Deere 310L...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
(10) Massey Ferguson Tractor Weights (A65640)
(10) Massey...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
