Towed Tractor Rollover
/ Towed Tractor Rollover #51
My brake controller is adjustable. My 2600 pound trailer needs a lot less brakes than my fully loaded GN. If I forget to adjust the controller after pulling the GN it will lock up the light trailer with very light braking.
/ Towed Tractor Rollover #52
I have had several close calls with whipping trailers. Every time it was caused by having too little tongue weight and I was able to regain control by applying the trailer brakes manually. These incidents were all over ten years ago when I wasn't early as experienced towing as I am now. Now I always make sure to load the tongue heavy. From what I have seen the gross weight of the load has little to do with the whipping it is all about the tongue weight though a heavier trailer can sure jerk the truck around more if it gets to whipping. Heaviest load I have pulled with a bumper pull was around 20k(load and trailer)on a pintle hitch trailer behind my dually and it tracked fine but I had about 2500lb tongue weight.
/ Towed Tractor Rollover #53
I see people pulling 10-15k travel trailers and toy haulers behind half ton trucks all the time.
I put as much distance as I can between my Cummins and them.
One of them jackknifed just outside of town a week or two ago when we had slight crosswinds.
They never learn.
/ Towed Tractor Rollover #54
Somewhat related question. Recently purchased an 18' 7K trailer. When adjusting the brakes according to the manual I could never get them to lock up, even with the gain set to 10 (highest setting).
Am I not hitting the brake pedal hard enough?
/ Towed Tractor Rollover #55
More likely a wiring issue. Brakes not wired right, maybe to the wrong terminal on the plug. Bad ground?
/ Towed Tractor Rollover #57
On a brand new trailer purchased from a large dealer?
/ Towed Tractor Rollover #58
Are they activating at all? Just not reaching the drum? You check for voltage at the truck?
OXBO PixALL Big Jack Mark III (A60462)
OXBO PixALL Big...
2020 CAT 308 (A53317)
New Holland 650 Hay Baler (A53317)
New Holland 650...
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
2023 Deere 317G (A60462)
2023 Deere 317G...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
