tow behind chipper/shredder
/ tow behind chipper/shredder #1
tirespin
Hi all - my second post already :)
To go w/ the B3030 that I will probably be buying shortly, I also want to get a tow behind chipper/shredder. I've considered the PTO models, but there's a number of sites that I may want to use it at, and I like the idea of being able to use it behind an ATV while someone else is working elsewhere w/ the tractor.
So that said - what's my best option? The common one is the troybuilt, 3", 10 hp, $700, but I have LOTS of scrappy alder, much of which is bigger than that. I'm thinking more like 5 inch, but can't find many that size that will chip and shred; they are just chippers (lots of blackberry and salmon berry that needs to be cleared as well).
Any suggestions?
Thanks,
Skip
/ tow behind chipper/shredder #2
I have a Bear Cat 71020 5" chipper with a 20HP motor on it. I have used it for several years. Chips 5" stuff down to nothing. Bearcat now offers this unit with a 24HP motor. I have stalled mine with soft wood. These unit run $3000-$4000. Here is a link to their site. Click Here
/ tow behind chipper/shredder #3
To get 5 inch capacity in a tow behind, you're going to get into some mighty expensive machines in a hurry. I've been the route of the Sears/Troybuilt/MTD machine, and I can tell you -- don't bother. Even if 3 inches were enough, you'll beat it to death in the first couple of jobs if you have more than a small suburban lot with 5 nursery trees on it.
Take a look at the Goossen as well as the earlier mentioned BearCat. Both are available with their own power or PTO driven -- which might prove to be a better choice once you start shopping. Why buy and maintain another power plant? I have the Goossen and it is simply amazing. I cut anything larger than about 4 inches for firewood. But, the 4 inch trunks disappear into the chipper about as fast as I can push it in, with very minimal branch removal. You do have to take the 1 inch branches off, but the smaller ones just fold up and go right down the chute. The shredder will dispose of the 1-1/4 and smaller stuff as fast as you can feed the hopper. Don't hold onto the end, because it is going in NOW. I am using it on a 35 HP John Deere 4410. I don't expect it works quite as well with a 25 HP gasoline engine, but it probably isn't too different. I got lucky and found mine used.
I had a twin trunked red cedar tree that was about 20 feet tall and bushed out all of 20 feet as well. I limbed it as high as I could reach first, then dropped the trunks. I chipped as I went, using the chainsaw until the ground was covered with limbs, then chipping until they were gone. When I dropped the trunks, I limbed it the rest of the way up, chipped those, and chipped the trunk up to about 3-1/2 inches. I was done by lunch time and had a wagon full of mulch.
/ tow behind chipper/shredder #4
Troybilt is made by MTD now. They bought them about 3 or so years ago. I don't think you'll get much of a 3" chipper/shredder for $700. My 8 hp Troybilt was originally about $1100 more than 10 years ago. An equivalent to it in a 3 pt runs about $1500-1700 now.
My Troybilt will only do about 1" stuff with 8 hp. Even the MacKissic connected to my 12 hp Gravely won't do any larger stuff, unless it's decayed and dead. Up to around 3" stuff in that case.
Another thing: my Troybilt can only be towed a very limited distance. The wheels on it aren't good enough for very far. Had one come off and put it back on and drilled a hole for a cotter pin. They were only held on with a self-lock gizmo hammered onto the end of the axles. One is still this way.
Ralph
Peruzzo Canguro 1600 Collection Flail Mower
Peruzzo Canguro...
(UNUSED) REDDICK OFFSET DITCHER, 3PT (A64278)
(UNUSED) REDDICK...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
2019 JOHN DEERE XUV855M S4 CART (A66091)
2019 JOHN DEERE...
2013 Ford Escape SUV (A64557)
2013 Ford Escape...
