ruffdog
Super Star Member
- Joined
- Dec 31, 2011
- Messages
- 12,492
- Location
- cowville, banana republic
- Tractor
- Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
That's why I missed it, I haven't seen or read the other thread.
The hydraulic top link was provided when I first bought the tractor and requested topntilt with it. I knew very little then and did not think about the link of the top link and how that could affect things.He's invested in his aftermarket *hydraulic top link already.
I haven't run across an "extension" like you've pictured, but it would be very simple to fabricate if you weld.
*I think
Maybe altering the attachment could be a non welding solution.
I like this idea. I can make a template for the size and hole locations out of some scap wood and take it to a machine shop. Thanks! In the meantime I will try my 'blocking to tilt' idea - just posted.Doesn't even need to be welded. Couple of pieces of flat stock the appropriate width 4" or 6 " with holes drilled say at least 4 on the tractor side for a pair of pins with spacers and the normal set of 3 (6) on the implement side
Gator, I looked at those - and still looking. What I could not resolve for myself yet was how that would work out without a fixed connection point. What I mean is, I am wondering if it would not put the force up or down rather than straight out as it would if the top link implement hook up was directly connected to a pin. I mean, I see two swivel points with that item and not sure how that would work out as the uses (images) I have seen accompanying these kinds of extenders seem to be otherwise. Not sure. Thanks for the input. I will keep thinking about these. Maybe there would be a way to make that device more 'fixed' - i.e., less maneuverable up and down.Look at this. I would advise putting the device on the implement end of the top link and stay away from adding a stress factor to the top link connector location on the tractor.
