Top link extender help - finding one like the included photo
   / Top link extender help - finding one like the included photo #1
beowulf
Central California Foothills
Kubota L3410 HST, J Deere riding mower
I posted this a minute ago but somehow lost it. I hope this does not go in twice. Anyway, my top link is inconveniently short at times - by about 2-3 inches typically. I can make the connection with a bit of hassle and sometimes need to use a lever to lift the back of an implement to tilt it forward.
I have searched here and elsewhere for solutions and in an old TBN post, discussing top link extensions, I found this photo. It seems it would work out for me but I cannot find it anywhere to buy after exhaustive online searching. So, asking if anyone knows where I can find one to buy - assuming it would fit my Kubota L3410.
I have also looked at the 'tongue' -swivel type that attach at the implement end but I prefer the more stable bracket mount to the tractor side. A longer top link cylinder is an option but very expensive.
   / Top link extender help - finding one like the included photo #2
If you can weld you could make one. Not that hard. I made one for my L6060 a few years ago and it still works fine. If you don't have the equipment you could get a welding / fab shop to make one or better yet get a friend to make one for you. That's what friends do, lol.
   / Top link extender help - finding one like the included photo #3
I made something similar when I put the PAT's quick hitch extensions on the draglinks. I used some 1/4" plate. Made 2 of them and put a spacer in between them. Been running this for 200 hrs no problem
   / Top link extender help - finding one like the included photo #4
How long is your top link when extended?
Have you compared your top link length with aftermarket top links?
Maybe Cat 2 top lInk with bushings for smaller pins?
Here is a list of sizes from a UK company. Probably comparable sizes are available here.
Bruce
   / Top link extender help - finding one like the included photo #5
What sort of implement(s) are you attaching to your 3-point? I have a Kubota M6040. In ALL cases - my top link is more than adequately long.
I wonder. When you lengthen your OEM top link - do both ends extend( unscrew) equally?
If you are only unscrewing one end of the top link - this could be the problem.
   / Top link extender help - finding one like the included photo #6
I wondered the same thing as any factory third link that I have ever hooked up to an implement was sufficient when screwed out, but with that being said the OP knows what he has so I am like some of the other poster's and would try to weld me one up and if not any decent welding shop should be able to cut, fab and weld you one up in short order.
   / Top link extender help - finding one like the included photo #7
He's invested in his aftermarket *hydraulic top link already.
I haven't run across an "extension" like you've pictured, but it would be very simple to fabricate if you weld.
*I think 😉
Maybe altering the attachment could be a non welding solution.
   / Top link extender help - finding one like the included photo #8
*I think 😉
I guess I missed the part about it being an aftermarket hydraulic third link when I responded.
   / Top link extender help - finding one like the included photo #9
I miss something "speed reading" all of the time myself. 😉
   / Top link extender help - finding one like the included photo #10
Hmmmm......I missed that part about the hydraulic top link also.
   / Top link extender help - finding one like the included photo #13
Doesn't even need to be welded. Couple of pieces of flat stock the appropriate width 4" or 6 " with holes drilled say at least 4 on the tractor side for a pair of pins with spacers and the normal set of 3 (6) on the implement side
   / Top link extender help - finding one like the included photo #14
The cylinder rod can be extended also. A welding shop or capable welder can add length to the rod.
   / Top link extender help - finding one like the included photo #15
Bruce
*I think 😉
The hydraulic top link was provided when I first bought the tractor and requested topntilt with it. I knew very little then and did not think about the link of the top link and how that could affect things.
Thanks to everyone for reading. My top link is hydraulic - came with the tractor when I ordered it with TnTilt. The implements used mostly are box blade, and grader blade, and rarely the middle buster, and now - a new pto chipper, The chipper is the most difficult to get hooked to the top link as it weighs 710 lbs (Very hard to tip it forward enough to connect but doable) but they all require some effort or creative approaches at times - but the hook ups are all doable. As I have been thinking about this, I may have another solution - given that I am not changing things out that much, and once hooked up there are no issues with operating. What I can do for the chipper is to have a 2 x4 or 4x4 situated so the back of the implements can be sat down on that which would tip the front top link connection forward. They could be easily unhooked and ready to be hooked up again later. Given that I am typically only 1-2 or 3" short, this should work and would resolve the issue for me - as I said, I am not switching out implements that much. The box blade is left on until I need to use something different. I also have a post hole digger and a 5 foot rotary mower but will be selling both of those.
I like this idea. I can make a template for the size and hole locations out of some scap wood and take it to a machine shop. Thanks! In the meantime I will try my 'blocking to tilt' idea - just posted.
   / Top link extender help - finding one like the included photo #19
Look at this. I would advise putting the device on the implement end of the top link and stay away from adding a stress factor to the top link connector location on the tractor.
Gator, I looked at those - and still looking. What I could not resolve for myself yet was how that would work out without a fixed connection point. What I mean is, I am wondering if it would not put the force up or down rather than straight out as it would if the top link implement hook up was directly connected to a pin. I mean, I see two swivel points with that item and not sure how that would work out as the uses (images) I have seen accompanying these kinds of extenders seem to be otherwise. Not sure. Thanks for the input. I will keep thinking about these. Maybe there would be a way to make that device more 'fixed' - i.e., less maneuverable up and down.
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2022 THOMPSON PUMP 6X6S1 PORTABLE PUMP (A59823)
2022 THOMPSON PUMP...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
