tooth bar???????
/ tooth bar??????? #1
BLUEBONNET2
harrison county, tx (NE TEXAS)
nortrac 25 xt JD zeroturn 54", briggs mtr.
good morning,
looking at yankee warehouse 60" tooth bar.........would you weld it to a bucket?.....prolly never take it off.........light work on 12 acres, spreading dirt, gravel....etc...........
just asking..........
good luck,
PURA VIDA,
bluebonnet2
/ tooth bar??????? #2
Well I guess you don't have to use it much for snow, but I take my tooth bar off for snow. the only other reason I can think of that supports just bolting it on would be the "re-sale" value. if you ever sell or trade in your FEL with the tractor, it might be a take-a-away in value.
/ tooth bar??????? #3
Assume you are aware that if you like to smooth the dirt and gravel by back-dragging the bottom edge of the bucket, the tooth bar will impair that somewhat. Another reason to make it removable for certain projects.
/ tooth bar??????? #4
Bolting it on is easier and just as secure. You never know why you might want to take it off.
/ tooth bar??????? #6
For instance if I want to use clamp-on pallet forks I need to remove my Piranha.
/ tooth bar??????? #9
Just for the back dragging alone is a good reason to bolt it on. With a box blade and the smooth edge of the front lip of the bucket you can make a pretty road instead of a little garden row look.
/ tooth bar??????? #10
Just received my 60 inch bolt on TB tonight. It took about 15 minutes to install. I worked it for a couple of hours tonight digging, back dragging, and digging up a concrete patio.
I don't have much time on mine yet, but there does not seem to be any play between the bucket and tb. I am impressed by how the tb seems to be one with the bucket, being only secured by two 5/8 bolts. Mine did not come with mounting instructions, but the install was about as easy as it gets. I did put vertical down pressure on the toothbar to force the tb female wedge tightly against buckets cutting edge, then I tightened the bolts. It feels extremely solid. I weld most of my stuff that takes a beating, but I don't feel it will be necessary on this.
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
2008 Ford Expedition SUV (A61574)
2008 Ford...
Challenger MT800/MT800B Series Tractor Service and Parts Manuals (A63117)
Challenger...
