tooth bar???????
/ tooth bar??????? #1
BLUEBONNET2
harrison county, tx (NE TEXAS)
nortrac 25 xt JD zeroturn 54", briggs mtr.
good morning,
looking at yankee warehouse 60" tooth bar.........would you weld it to a bucket?.....prolly never take it off.........light work on 12 acres, spreading dirt, gravel....etc...........
just asking..........
good luck,
PURA VIDA,
bluebonnet2
/ tooth bar??????? #2
Well I guess you don't have to use it much for snow, but I take my tooth bar off for snow. the only other reason I can think of that supports just bolting it on would be the "re-sale" value. if you ever sell or trade in your FEL with the tractor, it might be a take-a-away in value.
/ tooth bar??????? #3
Assume you are aware that if you like to smooth the dirt and gravel by back-dragging the bottom edge of the bucket, the tooth bar will impair that somewhat. Another reason to make it removable for certain projects.
/ tooth bar??????? #4
Bolting it on is easier and just as secure. You never know why you might want to take it off.
/ tooth bar??????? #6
For instance if I want to use clamp-on pallet forks I need to remove my Piranha.
/ tooth bar??????? #9
Just for the back dragging alone is a good reason to bolt it on. With a box blade and the smooth edge of the front lip of the bucket you can make a pretty road instead of a little garden row look.
/ tooth bar??????? #10
Just received my 60 inch bolt on TB tonight. It took about 15 minutes to install. I worked it for a couple of hours tonight digging, back dragging, and digging up a concrete patio.
I don't have much time on mine yet, but there does not seem to be any play between the bucket and tb. I am impressed by how the tb seems to be one with the bucket, being only secured by two 5/8 bolts. Mine did not come with mounting instructions, but the install was about as easy as it gets. I did put vertical down pressure on the toothbar to force the tb female wedge tightly against buckets cutting edge, then I tightened the bolts. It feels extremely solid. I weld most of my stuff that takes a beating, but I don't feel it will be necessary on this.
2025 LandHonor MGB-72-44W Rotating Grapple Skid Steer Attachment (A61572)
2025 LandHonor...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2014 Chevrolet...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
PLEASE READ (A63117)
UNUSED WOLVERINE QUICK COUPLER 3 (A64281)
UNUSED WOLVERINE...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
