TOOTH BAR
/ TOOTH BAR #1
GIJOE
Baton Rouge, La.
MAHINDRA 3510 w/ ML112 FEL
Here is a tooth bar I built this past weekend. 4"x1/2"x72" cutting edge with eight Fabco teeth.
Joe
/ TOOTH BAR #2
Nice work Joe!
If you don't mind me asking, how much are those Fabco teeth?
/ TOOTH BAR
Zick,
I paid $240 including shipping. I didn't have any dealers in my area, so they were shipped directly from Fabco. They are the TB-1001-23 shanks.
Joe
/ TOOTH BAR #4
GIJoe,
Thanks for the great pictures of the toothbar you installed. I bought a used tooth bar this weekend (slight ripple in the middle, but not enough to bend my bucket edge I think) and Sunday was just laying it up to the bucket to see how it fit in. I was trying to get it in upside down. It would have worked that way, but now I can see how to lay it in. I have been around machinery my whole life, but never paid much attention to a toothbar before. I travel for work during the week, so I can't wait to get home to try it that way. Your work looks good on that toothbar.
John
/ TOOTH BAR #5
Yeah, super nice work indeed.
Have you had a chance to try it out yet? Adding one to my bucket sure made a big difference in how it digs, but also in picking up rocks, logs and brush. I have never had it off since I installed it.
/ TOOTH BAR #6
Very nice work!! Thanks for the part # too. I am looking into either building one or buying one for my corral cleanups this year. Also as 3RRL stated, it would be nice for the rocks I have to move too. But I would have to remove it for the snow season tho.
/ TOOTH BAR #7
Very nice!
Do you know what the distance is from the bottom of the cutting edge to the top of the bar? I'm wondering if those adapters would work for me and they don't list that dimension on the Fabco site.
Are those the 8023 teeth?
Thanks,
Brent
/ TOOTH BAR
Hey Guys,
Thanks for the feed back.
3RRL,
No, I haven't had a chance to use it yet. I raked up a bunch of tree limbs and leaves and have my grapple attached at the moment trying to get that mess cleaned up.
Oh yeah, I don't want to scratch the paint off of it just yet.:rolleyes:
RADE0041,
If I understand what you're asking, the original cutting edge is 1/2" thick and welded onto the bucket which is 3/16" thick and the cutting edge the shanks are welded to is another 1/2" thick for a total of 1 -3/16" thick. They are the TB-1001-23 shanks.
Joe
/ TOOTH BAR #9
Thanks! Exactly what I was looking for. Sounds like those shanks will work for me too.
/ TOOTH BAR
vic4news said:
Nice job on the tooth bar. Did you use a stick welder? If so what rod did you use?
Vic
Thanks,
No, I didn't use a stick welder. I used my Millermatic 210 mig welder with .035 ER70s-6 wire and C25 gas.
Joe
/ TOOTH BAR #12
Nice job! I've always had trouble finding these cutting edges. Where did you get yours?
/ TOOTH BAR
RichT,
Thanks,
I've had it for a couple of years. It was a piece left over that was handed down from a friend. I'm not sure where he got it from, but you can get a piece from this company. Discount Steel - The widest selection of steel, aluminum and other metals at discount prices. Click on "steel" then "hot roll" and then "beveled cutting edge". You can order any length you need, and there is no minimum $$ order. I've ordered small pieces of steel and aluminum from them before and have never had a bad experience.
Joe
/ TOOTH BAR #15
Nice Bar!
well I don't want to start a new tooth bar thread so I though that I could share the source of where I purchased my teeth and shanks.
This was this best price that I could find. I ordered 6 shanks and 8 teeth with shipping to maine it was $88.00 Now to find time to put it together
RippermTeeth
20ATooth1 1/16"
$3.25​
20WOShank Flush Mount 1 1/16"
$9.00​
/ TOOTH BAR #16
GIJOE,
I just when back and looked at the pictures again and noticed that you welded the tooth to the shank in the crimp hole. Why? will they fall off if I just crimp?
Thanks
Phil
/ TOOTH BAR
philbuilt said:
GIJOE,
Thanks
Phil
The tooth is not welded to the shank. These are not crimp on teeth. What you are looking at is the end of the pin that is driven through the hole to hold the tooth on the shank.
Joe
/ TOOTH BAR #18
Joe, based on the Fabco TB-1001-23 specs, these shanks look like they may fit my B26 bucket with the bolt on cutting edge. I'm hoping you can take a critical measurement "D" shown in the attachment.
/ TOOTH BAR
RichT,
The measurement you ask for is 1-3/8". hope this helps.
Joe
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2017 CATERPILLAR 980M WHEEL LOADER (A65056)
2017 CATERPILLAR...
PALLET OF CUT-OFF VALVES (A68842)
PALLET OF CUT-OFF...
2008 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
CAT 315CL Manual Thumb (A68134)
CAT 315CL Manual...
