Tooth Bar - are they useful?
/ Tooth Bar - are they useful? #1
Mark45
I'm still working in buying a new 40 +/- hp JD or Kubota (depending upon warranties, etc). But I've got a lot of brush like Blackberry bushes, ferns and other stuff that I need to clear out before I can find all the tree stumps to remove. I was thinking that a tooth bar on the front loader would be a reasonable way to drag that stuff out and pile it up for a winter fire.
Anyone use it for that? Do you think a tooth bar is worth getting? Would something like that void the warranty?
Also, I'm sure someone else has asked this question before - so is there a way to search the groups for certain words?
Thanks
/ Tooth Bar - are they useful? #2
Why not just brush hog it and be do with it? A brush hog will shred all that stuff and you wouldn't have to mess with it any more.
/ Tooth Bar - are they useful? #3
A toothbar is the greatest thing....... /forums/images/graemlins/grin.gif
Get it when you order the tractor, or take 45 mins and put it on later, you'll never regret it.
A search on toothbar and you'll get hours of reading. I put one on 2 weeks ago, the pictures are in the Pictures Forum, search there.
Or just Click here
Jerry
/ Tooth Bar - are they useful? #4
I would recommend getting a loader with a skid steer style quick attach coupler. Then buy a slightly smaller digging bucket with teeth and a slightly larger general purpose bucket.
Hoeman00 will back me up that it is better to have two skid steer style buckets than one bucket with a toothbar. It accually doesn't cost much extra either. Takes me about 30 seconds to change buckets.
Eric
/ Tooth Bar - are they useful? #5
I think toothbars are a very valuable piece of equipment.
/ Tooth Bar - are they useful? #6
Mark,
A toothbar is an incredible tool and probably the best value per dollar you'll ever find relating to your loader and bucket except for bucket hooks. I have a 61" Deere loader bucket and got a nice toothbar that cost me just under $300 at my door and absolutely love it. I highly recommend one and a pair of bucket hooks, too. /forums/images/graemlins/smile.gif
Good luck with whatever you decide. I hope this helps. /forums/images/graemlins/smile.gif
/ Tooth Bar - are they useful? #7
I don't have atoothbar....
Get one, moving the brush once you dig it out without one is hard. If I don't get just the right angle with my bucket, I lose the pile and have to start all over again. I think the toothbar would help me a lot. The brush really doesn't 'hang" onto anything in the FEL without the toothbar.
I know you can get long bars that protrude specifically for moving brush but I think the toothbar would be good enough and have other uses.
/ Tooth Bar - are they useful? #8
Tooth bars are great for all the reasons stated plus, it adds strength to the bucket lip. I just lifted a 2400lb cutter from a trailer and wraped the chain around the bucket with the lifting edge against the tooth bar. Didn't bother it a bit. Only down side to a tooth bar is if you are doing alot of lose gravel, dirt, etc. moving. With the tooth bar you lose that nice straight edge for the final clean up or grading.
/ Tooth Bar - are they useful? #9
I solved this. Mine attaches with two bolts on the side. I cut off two hitch pins and redrilled the pin hole. Now instead of the bolts I use the hitch pins. Now it takes me all of about 30 seconds to either remove or put my toothbar on.
/ Tooth Bar - are they useful? #10
Sounds like a great idea, but having a hard time picturing it. Was the hitch the exact same size? Is the hitch pin on the outside? A picture would be great!
/ Tooth Bar - are they useful? #11
Yes the hitch pin is the exact same size. You can buy hitch pins in any size. Just picture the bolts on the sides that hold the toothbar on. Now instead of bolts you have a cut off hitch pin to the exact same length as the bolt. You just put a pin through it and you are ready to go.
/ Tooth Bar - are they useful? #12
Doc,
I like that idea a bunch. Do you use clips or pins on them? Any trouble losing them?
/ Tooth Bar - are they useful? #13
I don't know...
It only takes me a couple minutes to take my tooth bar off with the bolts...I think I will stick with the bolts. Like the idea of the pins and clips though. I just don't take mine off enough to worry about a few seconds...or minutes.
As far as usefullness...I would not be without mine.
Anyone who actually owns one regret it? Please speak up!
/ Tooth Bar - are they useful? #14
I have a regret about mine, got it two weeks ago and regret not getting it years ago! I would never go without one again.
/ Tooth Bar - are they useful? #15
Mark, if you plan on doing any kinda digging, get the toothbar!! Its worth its weight in gold to me. As a matter of fact, I consider the toothbar the number one attachment. It should come standard on all buckets. /forums/images/graemlins/smile.gif
Ken
/ Tooth Bar - are they useful? #16
Iv'e pushed a lot of brush with and without a toothbar. Much more effective with. I agree with all on the usefulness. I have mine on a 4in1 bucket and found the teeth are a real help in taking the trash out to the road. See attached.
/ Tooth Bar - are they useful? #17
Isn't the toothbar a little loose with the pins vs bolts? Maybe it doesn't matter? Do you have a pic?
/ Tooth Bar - are they useful? #18
My only regret about getting a toothbar is nicking my shins on it when I walk around the front end of the parked tractor. Need to remember to lay the teeth flat on the ground.
Otherwise I cannot imagine the bucket being much use with out it. Pulling up and moving brush and small trees, pushing logs, digging out fill from the shale pit, edging boulders out of my mowing path, moving old culvert, pulling up rotten stumps, etc. I don't move much soft, mounded material.
I'll repeat someone else's comment: best dollar spent.
Chas
/ Tooth Bar - are they useful? #19
Hello, I love my toothbar. Got it based on Henro and Bird's recommendation and it is great for clearing brush. I have about two acres I am clearing of brush and small trees and it is great at popping 3-4" trees out of the ground, after you beat them up a bit. I also use it to clear a swath prior to getting the mower in there. I pull up, lift the bucket, place the teeth down, put the bucket just touching the ground and back up. This pulls all the grape vines, weeds, small trees, etc and allows me to then see what is in there. I used to do this by hand and then scratch the poison ivy rash for the next three weeks - boy does this method work for me.
For moving brush it is great. Without it I don't know how you could pick up a felled tree.
Mine is bolted. I will be removing it for the Winter which starts here in two weeks in Upstate NY - kidding.
Best of Luck, Frank D. /forums/images/graemlins/smile.gif
31" Minin Excavator Bucket (A66285)
31" Minin...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2005 Kubota L39 (A64126)
2005 Kubota L39...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
213097 (A64276)
213097 (A64276)
Kubota L175 Tractor (A62613)
Kubota L175...
