Tools a tractor owner must have
   / Tools a tractor owner must have #21
Extremely handy and necessary.
Home Depot now sells a crescent wrench - ratcheting style. Gonna pick up 1 of each size, they work great adjusting the 3PT links.
The links on my Mahindra 7520 adjust by lifting the square tubing with handles away from the notched stays and turning. No need for a wrench.
Only thing I need is a pry bar to align my quick disconnect attachments if I get them off to one side.
   / Tools a tractor owner must have #22
6" channel locks and a 12" crescent wrench and I can do almost anything. If not I have a whole slough of stuff in the truck.
   / Tools a tractor owner must have #23
I've been installing a 3rd, 4th, 5th SCV kits and a Power Beyond kit on my 4200, and crowfoot wrenches are a necessity that I never felt I would ever need. Now I have bought a bunch of them (regular & flare nut) from cheap (Neiko) on Amazon.com to Sears to a couple of Snap-On's (1-3/16" & 1-1/8"), and I still could use a couple of more. I've found the hydraulic kits use a mix of metric and SAE wrench sizes...what a pain.
Large combination wrenches are also a must. My largest is a 1-5/16" in SAE and 30mm in metric. I still need to get an air impact wrench and ratchets.
I've had my torque wrench for 30+ years and it has gotten more use in the past 5-years than in all the years before.
I know I've forgotten more tools; but this is what I've encountered so far.
   / Tools a tractor owner must have #24
Long pry bar. 5' or 6' long. Often called a railroad bar and used to adjust 3pt attachment position.
pair of 12" adjustable wrenches.
Sockets in the sizes you need. Often larger than 1". (I use up to 1&3/4")
Grease guns. At least one with a straight steel line and one with flex line.
   / Tools a tractor owner must have #25
I find this real handy, Called a spud wrench. The tapered handle is great for aligning holes. One of those things I didn't know I couldn't live without until I had one:)
   / Tools a tractor owner must have #26
3lb short handle sledge hammer.... for adjusting things that are almost in alignment.
agree with
crescent wrenches
phone
There are many things I wouldn't be able to accomplish with my 3lb hammer. Some things just need to be beat into submission.
My tool collection has doubled since I got my tractor. I had what I needed for auto's, and most of that worked, but as you know tractors use huge nuts and bolts.
Wedge
   / Tools a tractor owner must have #27
As far as Carring on the Tractor away from the Shop. 2 cresents,1 visegrip , Hammer. Prybar , chain, Grease gun , Pliers , But Most Used by Me are a set of good wire cutters For the Ocasional Wire that gets Rapped up Either around the axles or Mowing blades. Also Tubing Wrenches to Snug the Ocasional Lines that might loosen from Vibration That cant allways be Reached with a Cresent, Such as Injector lines . Works for Me for the most part . Great topic Though .
   / Tools a tractor owner must have #29
I agree with the cell phone and to ask wife to bring other tractor and chain or pickup to go get a part. When I walk in before she expects me while using tractor or other equipment she greets me with, "what is broken now? Love that woman. Sure wish she was not right of often. kt
   / Tools a tractor owner must have #30
I have seen all kinds of posts about how to fix tractors, or what tractors to buy, or whether or not Harbor Freight tools are a good thing to buy. I was reading a post someone was answering for a new tractor owner and I wondered, what tools or equipment have the most of us felt was something we do not know how we could live without when it comes to working on or using our tractors. In another post I mentioned that an Air compressor is something I consider mandatory. I also think an air powered impact wrench is something that I would not imagine not having. I have several others but am curious to see what other people find the most useful.
I believe this post has been covered before.. but here's what i like
large set of basic tools.. sockets or wrenches.. usually 1/2" drive covers stuff up to CUT's and small utilities.. but a 3/4 set really opens up the possibilities for ya.. I've had a 4' pipe on the end of my 3/4" drive breaker bar jumping on it to torque down 2" nuts before..
A nice maul, both steel and copper or brass.. the copper/brass mauls won't mar steel or cast surfaces. Get a good set of drifts and punches to go with that maul.
A heat source of some kind.. whether o/a bottles.. or mapp gas.. or even a small plumbers propane torch.. anything that makes heat can help to get a stuck 'thing' off. Add to this an angle grinder and a welder of some sort.. even a cheap stick welder... being able to cut something off and then hot-glue it back on is a real plus... especailly whn the machine is broke down and not easy to trailer.
penetrating oil.. anything fom expensive 'kroil'.. to regular 'pb blaster' to home-brew stuff like kerosene mixed with atf fluid in a squirt bottle.
A few prybars of various makes and sizes.. tire irons do double duty for this.
big jacks, bottle, floor and hi-lift tractor jacks.. to go along with this.. a variety of jack stands, and good timber cribbing.. absolutely no hollow cell concrete blocks.. solid concrete pillow blocks as a last resort.. but nothing hollow cell.
An oring assortment pack, couple tubes of thread pucky and generic gasket goop.
an air compressor
Now.. those are the tools to have in the shop.. the stuff you need on the tractor in your limited space tool box:
Big crescent wrench.. (makes a great hammer.. in a pinch.. probably an adequate wrench as well )
ball of bailing wire
gas pliers that adjust small / large and have the wire cutter piece at the base of the jaw... sure.. you'll probably have to replace all the bolts and nuts and fittings you use these on.. but when you are out int he field stuck.. it sure beats hitchhiking back home for the correct 'whatever' tool.
Big flat blade screwdriver .. makes a great prybar.. might also back a standard head screw out if needed... have a small philips on hand as well as a couple extra hose clamps and extra lynch pins, and a shop rag.
Last time I broke down in the field 4m away from home and had to remove and blow out my fuel strainer, and lines from the tank to the injector pump.. those tools were so helpfull.. the gas pliers, big wrench and shop rag.. beat walking home...
soundguy
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
2024 Frontier FL1061S Hydraulic Flail Mower (A56436)
2024 Frontier...
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CASE TV450B SKID STEER (A60429)
CASE TV450B SKID...
