Tools a tractor owner must have
/ Tools a tractor owner must have #1
gemini5362
Ozark Mountains in Arkansas
Montana 4940C
I have seen all kinds of posts about how to fix tractors, or what tractors to buy, or whether or not Harbor Freight tools are a good thing to buy. I was reading a post someone was answering for a new tractor owner and I wondered, what tools or equipment have the most of us felt was something we do not know how we could live without when it comes to working on or using our tractors. In another post I mentioned that an Air compressor is something I consider mandatory. I also think an air powered impact wrench is something that I would not imagine not having. I have several others but am curious to see what other people find the most useful.
/ Tools a tractor owner must have #2
I suppose it depends on what kind of work you intend to do, and how much work your tractor will require. Beyond those considerations, mostly just car maintenance stuff. I'd put a good floor jack pretty high on the list. Of course, socket sets including larger sizes for some of the bigger hardware on tractors. Check also SAE vs. metric as a lot of these machines are all metric.
I've been fortunate in that I haven't had to do much wrenching on my tractor. And thankfully, nothing related to the diesel systems as I don't have much know-how there!
/ Tools a tractor owner must have #3
Torque wrench.
a lot depends on budget and space. I have actually found that a hydraulic press comes in handy. If you are a klutz like me you wind up bending things. It is nice to be able to take them off take them to the press and straighten them.
/ Tools a tractor owner must have #5
The one thing I use the most is a 12" Crescent wrench. I carry 2 with me all the time. I can tighten or remove just about anything on my tractor. Another thing I find extremly handy is a 99 piece socket set from Sears.
Solo
/ Tools a tractor owner must have #6
Torque wrench.
Extremely handy and necessary.
The one thing I use the most is a 12" Crescent wrench. I carry 2 with me all the time. I can tighten or remove just about anything on my tractor. Another thing I find extremely handy is a 99 piece socket set from Sears.
Solo
Home Depot now sells a crescent wrench - ratcheting style. Gonna pick up 1 of each size, they work great adjusting the 3PT links.
/ Tools a tractor owner must have #7
A cell phone. I won't use my tractor without it. I am usually alone when on the tractor and if anything would ever happen, and I'm able to use it, a cell phone can summon help. Of course you have to have reception for it to have any value.
/ Tools a tractor owner must have #8
3lb short handle sledge hammer.... for adjusting things that are almost in alignment.
agree with
crescent wrenches
phone
/ Tools a tractor owner must have #9
also ratchet, socket(s) for changing snow blower shear pins in winter time.
/ Tools a tractor owner must have #10
14mm, 7/8" and crescent wrench is all I have in my pouch except when servicing, then the list gets bigger.
/ Tools a tractor owner must have #11
If you have the option of a Simplex jack over the hyrdraulic floor jack, take it as long as the size fits under your axles. I have a 10 ton Simplex and it fits right under the axles on my JD and it is never low on oil, never too much weight for it,(longer handle equals more capacity) and you don't have to worry about leaving it out in the rain a time or two.
A pair of vice grips, an electric impact if you don't have enough air(1/2" drive) and a ratchet strap to reseat the tires when you have a slow leaker and the bead comes unseated.
Did anyone mention a GREASE GUN???
David from jax
/ Tools a tractor owner must have #12
There is no such thing as "Tools a Tractor owner must have":p
There are some which would be handy but these vary as to the use and type of the tractor.:D
One type tool fits all is pure conqueror!:confused:
/ Tools a tractor owner must have #14
agree with
crescent wrenches
phone
Uh Oh, we're getting started with the hammer thing again.:rolleyes::rolleyes:
Mark
/ Tools a tractor owner must have #15
Hey, sometimes the only way to conquer something is to keep hammering at it:rolleyes:
/ Tools a tractor owner must have #16
D'ja ever notice that when your only tool is a hammer, all your problems start to look like nails!
(I can't take credit for that quote)
Another great one from my mother, though she can't take credit for it...
"When something moves, and shouldn't... use duct tape. If it doesn't move and should... use WD40"
I'm pretty sure those are the only two "tools" in her toolkit.
/ Tools a tractor owner must have #17
To have on tractor at all times - A couple of cresent wrenches, various wrenches, a pry bar to help hook up 3pt equipment, hammer, screw drivers, and extra pins. Oh and of course duct tape.
To have in garage to work on tractor - Impact wrench(electric or air), of course and air compressor, good jack(and jack stands), wood blocks, good socket set and torque wrench. Long pipe to help with stubborn bolts, grease gun, large hammer, never seize, locktite, filter wrench, and a large capacity oil pan.
Like someone else said a press is nice but a hammer does alright. Welder, torch, plasma cutter and such would be nice to fix or make modifications, but not a must have for most.
Cant think of anything else right now.
/ Tools a tractor owner must have #18
My li'l SWMBO has just started to believe that a 70 or so amp plasma cutter is an urgent necessity for anyone with a tractor and more than one implement.
So PLEASE don't say anything about little things, like cell phones and crescent wrenches.
I thought I was stretching things when I suggested I need a 50 amp plasma cutter. I will tell you the way i hinted to my wife that I wanted a welder for christmas.
I got a miller catalog then went to the page that had the welder I wanted. I highlighted that welder. Then I took an ink pen and made a circle out of asterisks around the welder. Then I took paper clips and put paper clips around the whole page. Then I ripped all the other pages except that one out of the catalog. I then put the catalog on her pillow.
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
2014 PUMA  END DUMP TRAILER (A65643)
2014 PUMA END...
Calf Creep Feed Hut (A66408)
Calf Creep Feed...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
GIYI Skid Steer Mount Stump Grinder  (A62679)
GIYI Skid Steer...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
