Tool Question
   / Tool Question
Here at a place about 5 blocks from my house they have MK 14' blades for $80 makitas and hiltis at $129 and Dewalts for $150.
They do pretty well on ebay. It is called Tool King.
   / Tool Question #12
Blades come in very different configurations and vary considerably in quality. MK makes good blades and they make "cheap" blades. A concrete blade is very different then a rock blade and very different from a asphalt blade. Some can be had for well under $100 and some will cost over $500. Once you use a high quality blade, the cost difference is easily made up in speed of cut and blade longevity.
Here is just a small sample of some of the blades available...
Asphalt, Green Concrete Blades - Toolfetch.com
   / Tool Question
I certainly understand this. In my MK 100 series tile/brick saw I use MK blades and they run me about $120 each. but if you keep them dressed they work for a long time. I am sure that the MK in question is a cheaper blade but for the amount of use it will see it could be a viable option.
   / Tool Question #14
I have the Makita saw picked it up for $850 including diamond blade & 4.5" angle grinder.
Runs like a champ - used it to make some holes in my basement for footings thread here
Also on the pool demo project although the volvo backhoe mounted hydraulic hammer was more impressive.
Tip - don't run the diamond saw blade in reverse, it may ruin it. A buddy re mounted it after using an abrasive cut off blade to cut rebar. It don't cut like it used to:mad:
   / Tool Question
Thanks Hazmat!!
It is nice to see someone with a makita to hear how good it is.:D
Thanks Shane
   / Tool Question
Update
I got a Makita 7311 for $700 new with a hammer drill.:)
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A56438)
2019 BOBCAT T630...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
14C SCRAPER (A58214)
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
